11-02-2019, 06:49 PM | #41 | |
Quarry Creeper Join Date: Nov 2018 Location: 🌎
| Re: ECX Temper gen 2... Quote:
True, I did not think about that aspect of it as far as supporting local hobby shops by bringing in business into them. Good Point. | |
11-02-2019, 07:04 PM | #42 |
Ok, so since I could not buy one online and the closest shop is 120 miles away I did some searching. I found one that looks new minus a broken driveshaft. It came from a hobby shop return and was apparently only out for a day or so before it got returned with the broken drive shaft. Looks to have been only driven inside. Everything else was said to be in good shape. I have read a number of reviews where people broke driveshafts on the first run, so at less then half the price, I think I got a good deal. I would have planned on replacing the driveshafts anyways so no worries there. Should be here next week. Last edited by Stomp; 11-02-2019 at 07:10 PM. |
11-02-2019, 07:04 PM | #43 |
So now the question is, what replacement driveshafts should I order? Thanks!
11-03-2019, 01:17 PM | #44 | |
Pebble Pounder Join Date: Mar 2016 Location: Harrisburg/York
Order the barrage draiveshafts. They are larger and metal ends vs plastic. You have to shave some plastic around the motor/tranny housing but not a big deal. Trim the shafts a little shorter Sent from my iPhone using Tapatalk | |
11-03-2019, 06:58 PM | #45 |
Thanks for the reply. Do you think these all metal ones would work? https://www.amazon.com/RZXYL-Univers...2832617&sr=8-1 I don't mind cutting and grinding them to length. They say they fit a 5mm shaft. Not sure if that is correct or not. Thanks again, Stomp |
11-04-2019, 04:52 PM | #46 | |
They look like they could work. I didn’t measure the shaft. Go ahead and double check the measurements. At least they aren’t expensive. Sent from my iPhone using Tapatalk | |
11-04-2019, 09:36 PM | #47 |
Newbie Join Date: Oct 2019 Location: US
(deleted)
11-05-2019, 04:08 PM | #48 |
Is the gear train strong enough to run heavier aluminum wheels?
11-05-2019, 06:08 PM | #49 |
| Re: ECX Temper gen 2... |
11-10-2019, 05:16 PM | #50 |
well I ordered that one set linked above. It looked nicely made, but the female spline was only about 1/2" long so shortening it would have left a smooth inside making it not work. I ordered this one from ebay as it is listed to be from 80-100mm. I measured the broken drive shafts and it measures 85mm at its shortest position. Hopefully these will work. At high speed they might wobble with the D shaped shaft, but on a crawler that should never be a problem. Anyone try these? |
11-10-2019, 07:47 PM | #51 |
The barrage driveshafts are larger but with shortening them and trimming the tranny housing fit/run fine. We have been running them for about 10 packs now without problems. Maybe give them a try if these don’t work out. Sent from my iPad using Tapatalk |
11-10-2019, 10:33 PM | #52 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Ewwww. D-shaped cross sections? That is literally the cheapest possible design for a sliding driveshaft.
11-11-2019, 01:14 PM | #53 |
01-21-2020, 02:56 PM | #54 |
Newbie Join Date: Dec 2019 Location: Peoria
Great Thread, got one of these for my son for Christmas, it has been a great little rig! added solder to the front wheels, went to the 380 size 27 turn motor, running 2s 1800mah zippy batteries and failed the driveshafts like you did. went with these steel ones, having to trim the trans and grind the shaft down on that one end. Trimmed the one shaft a little bit so it wouldn't bottom out. https://www.amazon.com/gp/product/B0...X1Z449C4&psc=1 He broke the upper link bolt yesterday..... I would suggest adding grease to the diffs, and checking the CV's that the cross pin set screw is tight. Great little rig!!! been a blast in the basement! and on rock piles! I also found some cheap SCX10 original metal axles that look like they would drop right in..... https://www.amazon.com/gp/product/B0...3GHZ2JVZ&psc=1 I'm playing around with the idea of getting rear steer on it..... guess I should start my own thread! |
01-21-2020, 03:06 PM | #55 | |||
Great deal, congratulations! Driveshafts are an easy fix. Quote:
X2 With the replacement driveshafts, should be fine. Those D-shaped driveshafts work but not a good design at all. Quote:
01-21-2020, 07:47 PM | #56 |
Newbie Join Date: Sep 2019 Location: Howell
How did you make the zippy pack fit? I have a 1200mah gens ace and I can't close the hood
01-21-2020, 09:09 PM | #57 |
And has anyone found stronger transmission gears?
01-22-2020, 08:04 AM | #58 | |
like mentioned earlyer make sure the set screw is tight and use lock tight on it that set screw and pin it likes to come out and lunch your spur gear and that tiny ring of metal used as a back up to hold the pins in is useless some one sugested soldering them in and ive found that works good for the most part atleast you wont loose the ring anyway and dont cut them down as the d part in the female side is only about 1/4 deep so any cutting pretty much ruins the shafts Last edited by ferp420; 01-22-2020 at 08:29 AM. | |
01-23-2020, 02:49 PM | #59 |
Newbie Join Date: Jan 2020 Location: Victoria
I have this crawler being imported, and i'm curious what parts does the Temper Gen 2 share with other ECX vehicles or other manufacturers like the Everest 16 or the Exceed?
01-27-2020, 11:57 AM | #60 | |
https://www.amazon.com/gp/product/B0...XBKQ70BE&psc=1 | |
ECX Temper gen 2... - Similar Threads | ||||
My new ECX Temper Gen 2 compared to my custom Losi Mini Rock Crawler | sully420 | Losi Mini-Rock Crawler | 11 | 09-26-2022 05:47 PM |
ECX Temper Gen 1 | FullyBad | General Scale Talk | 11 | 02-09-2019 07:32 PM |
ECX Temper | spectre | Losi Mini-Rock Crawler | 30 | 01-03-2017 11:59 PM |
My new ECX Temper | driftomaniacs | Scale Videos! | 0 | 02-03-2016 08:46 AM |
