Thread: Psycho’ PAT performance scale crawler
Old 05-24-2019, 07:08 AM   #1
Default Psycho’ PAT performance scale crawler
Saw this few days ago on Facebook. Seem like another high performance trail truck. Axles are available in AR60 style or AR44
Very high pinion gear in my opinion
On Suzuki Jimmy body now
Video link here: https://www.facebook.com/ventru.craw...7750329492664/
Teng is offline   Reply With Quote
Old 05-24-2019, 10:26 AM   #2
Natedog's Avatar
Default Re: Psycho’ PAT performance scale crawler
Chassis is ugly as heck and not scale at all, but it's all very innovative and I like the axle housings, just need regular end bits without the comp style tungsten weight holders.
Old 05-24-2019, 10:42 AM   #3
Hi,
It's not a scale chassis, it's a scale PREFORMANCE chassis, as hillkiller, or toyzuki, for example
Axles are made to be used with TRX4 gears.
CyberFox is offline   Reply With Quote
Old 05-24-2019, 11:39 AM   #4
Natedog's Avatar
Yes, I realize that, cool but I prefer scale.
Yes, great choice in axle gears, cheap, readily available, three ratios (stock, overdrive and underdrive), I like it.
Old 05-24-2019, 08:40 PM   #5
This rig needs some solid brass rear lockouts that hang low in some one piece 3d printed wheels, and a solid brass knuckle set that has some material hanging down in some one piece 3d printed wheels for the weight style to be legal in WRCCA and SORRCA rules. I have some designs. But im not willing to get them printed or machined. Pat has some awesome rig designs. The belly of this rig dates back to 2014 IIRC...
but yes, all WRCCA scale rules and SORRCA rules are for is performance. there are some exceptions in class 1 regarding rail height... but, still neither set of rules require c channel.
CM9000 is offline   Reply With Quote
Old 05-26-2019, 08:12 AM   #6
Originally Posted by CyberFox View Post
Hi,
I would not compare this goofy thing to Toyzuki. This thing is probably the closest "scale" chassis I've ever seen to TVP. Besides that, it's hideous.
Nice work on building a "scale" shafty. SMH.
Sent from my SM-N960U using Tapatalk
GTSLOW is offline   Reply With Quote
Old 12-20-2019, 09:26 AM   #7
Nice comment coming from someone who openly says he owns an R1 and uses the work "scale" 🤣😂 pat's rig is innovative and awesome performance wise.
Jdawg1977 is offline   Reply With Quote
Old 12-20-2019, 09:41 AM   #8
Moderator
JatoTheRipper's Avatar
You're awfully offended over a simple opinion...so is it your design?
The thing is ugly. It's hideous. And with all the colors in some of the photos it looks like Fisher Price is making it.
But it has some different things so I'm all for it. You'll never know what works and what doesn't unless you try it.
Old 12-20-2019, 09:46 AM   #9
since when does a chassis needs to look good to perform?
Sent from my LGMP260 using Tapatalk
Old 09-14-2021, 07:39 PM   #10
Did this platform ever amount to anything? Mainly wondering about the axles?
meatmonkey is offline   Reply With Quote
Old 09-15-2021, 09:11 AM   #11
Why would you want those axles as opposed to the stock ones?
MOguy is offline   Reply With Quote
Old 09-15-2021, 10:52 AM   #12
cartronicshn's Avatar
wow! i completely missed this thread, interesting to say the least, i am also curious if it was tested in a comp and how it worked.
cartronicshn is offline   Reply With Quote
Old 09-15-2021, 11:37 AM   #13
Googling the 3DTRX alxes does bring up a few shapeways listings.
HumboldtEF is offline   Reply With Quote
Old 09-15-2021, 03:52 PM   #14
Oh wow that thing is FUGLY!
TexasSP is offline   Reply With Quote
Old 09-15-2021, 04:28 PM   #15
I like it, looks f'n awesome. Probably works as good as it looks too.
garyk is offline   Reply With Quote
Old 09-23-2021, 07:41 PM   #16
They look like they offer a bit more pinion/castor split, noo more lower link mount bolts too loosen, and additional mounting locations for tuning. Also curious if the ring/pinion survive being located with an upper cover VS the conventional rear cover.
Old 10-05-2021, 03:01 PM   #17
Pretty sure it's popular in Europe, as it's made in France. I think there are a few stateside, though not sure who owns them or where..
It's a very interesting design, I think its pretty damn cool.
Cheers,
Gable
pcgab is offline   Reply With Quote
Psycho’ PAT performance scale crawler - Similar Threads
Scale shocks with performance?? Flippinrigs General Crawlers 2 01-20-2019 12:44 PM
Does the scale make up for performance? 1SweetRide RC4WD Trail Finder 2 16 10-06-2013 06:14 PM
Scale Vs. Performance: Where Do You Stand? crazydave Axial SCX-10 20 07-28-2013 11:30 PM
Scale Performance parts! Locked Up Locked Up RC 10 02-06-2012 09:08 AM
hot bodies psycho performance????? hardin316 Tires and Wheels 6 12-19-2006 05:58 AM
