05-12-2019, 10:22 AM | #1 |
Rock Stacker Join Date: Mar 2018 Location: Born in FL, stationed in Cali
| Slipper eliminator options
Between the Incision and Locked up RC slipper eliminator, which is the preferred choice? Also I assume the Robinson Racing 3-hole 58t spur #1558 will work with either of these kits. I need a bit more gear while maintaining the dust cover on the v1 3 gear scx10 trans.
05-12-2019, 10:36 AM | #2 |
Quarry Creeper Join Date: Jun 2018 Location: CRG
| Re: Slipper eliminator options
I've debated the same question myself. Ultimately, I really think any advantages would be negligible. The LURC piece is hardened steel, like their spools, so it would likely be indestructible. The Incision item is machined aluminum of presumably high quality and would offer lighter weight for a most likely imperceptible advantage in "throttle response" due to less "flywheel" weight. just my $0.02 |
05-12-2019, 11:55 AM | #3 |
Which ever one is in stock is the better option. I have both and I see no difference in performance. Sent from my SM-N950U using Tapatalk |
05-12-2019, 11:58 AM | #4 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
I went with Incision in my latest project because it's what was in stock.
05-12-2019, 04:21 PM | #5 |
I kinda like the design of the LURC piece better since it does not slot into a pin, however the incision piece would be lighter. I guess either of these will make much of a difference in the end.
05-21-2019, 12:39 AM | #6 |
Newbie Join Date: Aug 2018 Location: Chico
OG ax10 transmission case tree has a slipper eliminator on it you need the trans top shaft with the flat spot instead of the pin. For like twelve bucks it handles my 3300kv pro4 on 3s just fine. You also need a spur that bolts on
Slipper eliminator options - Similar Threads | ||||
SCX10 II - Slipper Eliminator | Locked Up | Axial SCX10 II | 9 | 10-14-2016 07:29 AM |
Slipper Eliminator Kits now available! | Locked Up | Locked Up RC | 15 | 06-02-2016 09:12 PM |
Slipper Eliminator | josh6575 | Vaterra Ascender | 4 | 11-07-2015 02:08 PM |
Locked-up Slipper Eliminator | Sh0rtBus | Axial Yeti | 3 | 02-06-2015 02:56 PM |
Slipper eliminator | Tru3Racing | Axial SCX-10 | 6 | 03-15-2011 02:55 PM |
