05-16-2019, 10:07 PM | #1 |
Rock Stacker Join Date: Mar 2018 Location: Born in FL, stationed in Cali
| A quickie on pinion size.
I know this has been discussed but I have not found a clear answer relating to my question: I converted my SCX10.2 to the v1 style trans with an aluminum trans case and stock motor plate. I am running a Crawlmaster Pro 13t with 11/56 gearing however I want to gear it down a bit more. It looks like I am almost our of room for proper mesh with the 11t pinion and was wondering if I can still get the gears to mesh properly with a 10t. With the v2 plastic transmission I had to modify the motor plate and transmission case to get the 11t to mesh properly (hence one of the reasons I converted to the older style transmission)
05-16-2019, 10:43 PM | #2 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: A quickie on pinion size.
I wanna say 11/56 is the lowest you can go without going to a bigger spur (which can cause driveshaft clearance issues) or making more clearance to move the motor closer. I had 10/56 in one of my rigs but I couldn't quite get the mesh as close as I wanted, it was very close to good though.
05-16-2019, 10:50 PM | #3 | |
| Re: A quickie on pinion size. Quote:
05-17-2019, 03:16 AM | #4 |
if you cant get the 10t to mesh get a 57t spur it should be bigger by just enuff to get the mesh right and lower your gearing alittle bit more
05-17-2019, 10:39 AM | #5 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I get a bit of gear lash with a 10/57t ... never thought it might be a bit small All metal gears I might add....sounds a bit like a chain saw Will try an 11t pinion and see how that works |
05-17-2019, 05:03 PM | #6 |
A plastic option in 57t would be nice but I am having trouble finding one. I enjoy having a quiet rig.
05-19-2019, 09:39 AM | #7 |
I run a 96t 48p spur and a 9t 48p pinion that is trally close to a 64t 32p spur in size. I just run stock drivelines and never had clearence issues. Sent from my SM-N950U using Tapatalk |
05-20-2019, 09:21 AM | #8 |
| Re: A quickie on pinion size. |
05-20-2019, 11:44 PM | #9 |
If you get a slipper eliminator from incision or can't, remember the name of the other company I think it's locked up RC then you can get a spur from Kimbrough. Or maybe the one from Kimbrough will just fit or you have Sent from my SM-N950U using Tapatalk |
A quickie on pinion size. - Similar Threads | ||||
Pinion size? | twisted up | Newbie General | 3 | 06-09-2011 07:46 PM |
pinion size? | mikeman84 | General Scale Talk | 6 | 03-28-2011 09:33 PM |
Pinion quickie | jayuk022002 | Axial SCX-10 | 2 | 11-25-2010 06:17 AM |
pinion size help | perez62682 | Newbie General | 4 | 03-17-2010 07:10 PM |
Pinion size | drzjohn | Team Losi Comp Crawler | 3 | 09-19-2009 02:16 AM |
