06-11-2019, 09:14 AM | #1 |
Quarry Creeper Join Date: Feb 2017 Location: Adirondack Park
| Metal Versus Plastic Axle's?
Not wanting to get off base in a Vanquish post so I started this, some are talking about how nice it would be to see a plastic axle housing from Vanquish. This is what I am confused about? Am I wrong to think that the weight of a heavier all metal axle down low is good? And that less weight of a plastic axle down low is now better? If indeed the more weight lower is better then why the push for plastic? Is the advantage strictly the cost difference?
06-11-2019, 09:26 AM | #2 |
| Re: Metal Versus Plastic Axle's?
I think people like plastic axle housing better because they slide over the rocks better and do not get hung up as bad. I personally like the machined alum axles on my VS4-10 and like the durability of them. I don't have to much of a problem with snagging on rocks as I try to pick my lines a little better. This is just my opinion though! |
06-11-2019, 09:27 AM | #3 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Metal Versus Plastic Axle's? Quote:
I would take plastic over alum any day. One after thought is the plastic doesn't show the rock rash the way alum does. Ernie PS: B-MOW71 and I posted at the same time, just about the same thoughts! Last edited by CODYBOY; 06-11-2019 at 09:31 AM. | |
06-11-2019, 09:37 AM | #4 | |
EDIT: But I do like the looks of nicely machined aluminum axles. And since my VS4-10 came with the Curries I will continue running them. And I do plan on buying the new VS4-10 Pro with the new offset F9 front axle. Last edited by B-MOW71; 06-11-2019 at 09:41 AM. | |
06-11-2019, 10:25 AM | #5 |
Rock snagging is not a big issue in my area as the rocks are mostly smooth. I have a VS4-10 with the aluminum axles on it and a VS4-10 Chassis kit with Axial axles on. The metal axle rig handles much better than the other one with plastic on the same indoor course for me. I consider myself old to RC but new to crawling, started RC in 1971 with a pulse proportional radio. If you have black axles I found a company called "Caswell" that sells a black anodizing touch up kit that works well to keep them looking good.
06-11-2019, 10:58 AM | #6 |
A question of weight on the outside of a axle. Being the axle's used are solid suspension if you put weight on one side that would put more down force on that one side. If you put weight on each side it would increase down force on both wheels. If you put the same weights in the middle of the axle it would also increase down force on both wheels again. If you switched to a metal axle would that not put more down force on the wheels more than a plastic one with out weights?
06-11-2019, 11:10 AM | #7 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
It’s all preference and set up. Light rigs can be great performers too if tuned right. Some of the TZ guys run 5 lb rigs. Others may run plastic housings and stuff the wheels with weights. My favorite have been the ssd housings for performance. Great price. Good weight. And a nylon pumpkin for smooth action. Best of both worlds imo. |
06-11-2019, 11:23 AM | #8 | |
06-11-2019, 05:18 PM | #9 | |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Sent from my SM-J327VPP using Tapatalk | |
06-11-2019, 05:36 PM | #10 | |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
Assuming the two axles weighed the same, it would be better to have that weight focused towards the ends of the axles to resist rolling over. If the metal axle is heavier in total than it may counteract that. | |
06-11-2019, 09:52 PM | #11 | |
Pro44 Axle Case for SCX10 II | |
06-11-2019, 09:58 PM | #12 | |
The theory is more about COG than down force, my thoughts anyway. Ernie | |
06-11-2019, 10:35 PM | #13 |
I'll take plastic housing with an F9 style carrier bearing retainer all day, every day. The aluminum that everyone uses for housings is pretty soft so it can gouge and get hung up. 7075 would be killer but rather expensive to make them out of although a much superior material choice. Weight at the knuckles is always superior. Ever see a tight rope walker holding a bowling ball with small plastic rods sticking out of it for balance? Gravitational force at the ends of the axle is different than at the center. Which is why all the brass doo-dads and trinkets all over the axles don't help do much outside of pay vendors bills. Last edited by WHITE-TRASH; 06-11-2019 at 10:38 PM. |
06-12-2019, 06:12 AM | #14 |
Ive got all three types, all alloy , all plastic, and SSD plastic and metal. I never have seen any difference on any of these sliding over rocks, what I do see is gouges in the plastic where i got hung up, the metal usually goes over , the softness of the plastic will "hold" the shape momentarily, where the alloy just scratches and slides over..... My take is the SSD combination is the best . Nylon and metal |
06-12-2019, 06:52 AM | #15 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
Weight closer to the ends of the axle also helps combat torque twist better.
06-12-2019, 08:04 AM | #16 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
Plastic pumpkins, stainless tubes for me, plastic chub and link mounts. Sent from my LGMP260 using Tapatalk |
06-14-2019, 09:21 AM | #17 |
Newbie Join Date: Jun 2019 Location: Seattle
you can't really say "plastic" and call that material science. All sorts of nylons, phenolics, different quality grades. Just like a 3d printer. different materials for different applications. |
06-14-2019, 10:47 AM | #18 |
| Re: Metal Versus Plastic Axle's? Plastic is a very generic term and in this case it is a very valid term. How else would you categories axles made from proprietary polymer blends?
06-15-2019, 10:03 AM | #19 |
Newbie Join Date: Sep 2017 Location: Los Angeles
| Re: Metal Versus Plastic Axle's? aluminum will definitely get hung up on the rocks and show the rock rash more but heavy axles are better. this why I love my boom racing metal axles, they may not be steel but they are harder then aluminum and hide the rock rash better then plastic and aluminum and they were cheap. probably why they are always out of stock lol. |
06-16-2019, 01:03 AM | #20 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Delrin FTW |
Metal Versus Plastic Axle's? - Similar Threads | ||||
SCX10 RTR plastic links versus aluminum: pros/cons | FreedomRiding | Newbie General | 9 | 06-27-2012 03:45 PM |
metal or plastic? | nd4spdbh | Tamiya TLT Crawlers | 6 | 09-23-2007 05:16 PM |
