06-21-2019, 04:18 PM | #1 |
Newbie Join Date: Jun 2019 Location: San Diego
| axial ar44 axle kits and gearing question
hey guys, if you were going to build the axial ar44 complete kit axles and wanted a front overdrive of like +5%, what gears set would you order and use where? the kit come with a 30 tooth ring and 8 tooth pinion. https://www.amainhobbies.com/axial-a...i31438/p661357 woudl it be the 30/8 out back and then this 27/8 in front? https://www.amainhobbies.com/hot-rac...xt9278/p710174 i really cant justify the price of the vanquish axles, even though i love the looks and understand they probably add some nice weight and performance gains. i know there are other ways to add performance for less money. |
06-21-2019, 04:37 PM | #2 |
| Re: axial ar44 axle kits and gearing question
Yup the 27/8 are front OD. Nothing wrong with axial housings, I've had a few sets of rock jocks and I'm not really a fan. They are good for basic things but the lack of additional upper link options and non removable c hubs makes them tough for custom performance based applications.
06-22-2019, 02:32 PM | #3 |
Thank you for the confirmation on the ratios. Yeah I hace never thought to myself...if I only had vanquish axles I would have done better.
06-22-2019, 09:46 PM | #4 |
Pebble Pounder Join Date: Jun 2006 Location: San Diego, CA
You can also pickup housings from Boom Racing. They are basically replicas of the Axial AR44 but metal. Add's lots of weight down low, well made and are $35 / ea.
08-09-2019, 11:07 AM | #5 |
| Re: axial ar44 axle kits and gearing question |
08-10-2019, 05:16 AM | #6 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
$40 for the gears. $50 for the Element gearbox. I went with the Element gearbox in my latest build. Run a tap in the white gears first when assembling them. If not the hex head will strip. |
08-12-2019, 07:21 PM | #7 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: axial ar44 axle kits and gearing question Hey I just picked one up too. If it works well I am going to get the steel gears. Can you give me more info on tapping the white gears. I guess I’ll know when I get it and build it. What size tap is it?
08-16-2019, 12:35 AM | #8 |
Pebble Pounder Join Date: Jun 2018 Location: New Zealand
Any other options for the front OD gears apart from Hot Racing?
08-18-2019, 07:31 PM | #9 |
axial ar44 axle kits and gearing question - Similar Threads | ||||
Axle Gearing Question - Ratios | bilinvic | General Crawlers | 20 | 10-03-2018 08:40 PM |
RESTOCK Axial Racing AR44 Complete Axle Set! | RPP Hobby | RPP Hobby | 0 | 09-26-2018 11:40 AM |
IN STOCK - Axial Racing AR44 Complete SCX10 II Axle Kit. | RPP Hobby | RPP Hobby | 0 | 04-05-2018 04:33 PM |
Coming Soon - RC4WD Teraflex Aluminum Axle Housing Set for Axial AR44 SCX10 II! | RPP Hobby | RPP Hobby | 0 | 02-02-2018 02:11 PM |
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
