06-29-2019, 12:21 PM | #21 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Which 1.9 Scaler? |
06-29-2019, 12:27 PM | #22 |
06-29-2019, 12:44 PM | #23 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
Much will depend on your setup. So it is hard to say... Size pinion, what motor (kv or T's). Lipo 2S or 3S.... etc. There are always trails. Question is how far are you willing to go. I have some easy trails very nearby. If i drive one hour up north, i have some sandy dune'like terrains. If i drive an hour south, i have esc smoking, axle snapping and driveshaft breaking rocks. My TRX's are the 2-speed version. It's always convenient to have high gear in back up, but personally i am a slow creeping and crawling mf. Dunno what kind of driver you are |
06-29-2019, 12:53 PM | #24 | |
| Re: Which 1.9 Scaler? Quote:
I guess it's better to have two speeds and not need it, or need the second gear every once in a great while, then to not have it and need it I'm like you, I like to drive sloooow. | |
06-29-2019, 01:07 PM | #25 |
True story.... I am an oldskool member of the Belgium Rockbounce Crew. Oldskool as in having to pass an "exam" on the graduationrock to become a member. A frigging piece of stone where you had to enter very slow creeping while sidehilling like crazy and then had to turn straight up to heaven while having to go full throttle because gravity was trying to pull you down. It was here where we learned the power of a slightly smaller pinion, 3S and Rockbeasts tires There are awesome microservo's these days. Amain has the Ecopower 640t. Better to have it, just in case... Then not having it. |
06-29-2019, 06:47 PM | #26 |
Rock Stacker Join Date: May 2019 Location: Upstate, NY
I'm also looking into more scale & trail slow running through woods than crawling. Did on-road/carpet long ago. Definitely going the kit route in a different way. In the end I'd like a locked rear, unlocking front, and the two-speed trans because both seem useful to get out of jams (rather than me having to get it out of a jam). This is strictly for fun and to hopefully get me out of the house even if only the back yard. I won't be going fast on trails cause I won't be able to keep up (mobility issues); walking on uneven terrain is difficult enough for me (not even sure a trail vehicle is a good idea - but that's never stopped me before!). So rather than go the Sport route, I'm thinking of going with TRX4 Chassis Kit upfront, add a Sport body or something not Defender-like but w/ more scale details than a painted body. Blazer/Bronco too plain. Now, I'm spending more $$ upfront than I should, but my thinking is the unlocking diffs and two-speed will add interest more than a Sport kit w/o the options. Or am I nuts?! Will the Sport w/ locked diffs and single-speed keep me as interested? Thoughts? Suggestions? Better ideas? Value is more important than cost. Thanks!
06-29-2019, 08:23 PM | #27 |
| Which 1.9 Scaler?
Enduro Sendero by Associated. Similar in layout to a late SCX10ii, but made with solid parts and front OD, the shocks will prove it all . Issue with the popular TRX 4 is a high COG, don’t even mention a cage and extras added on it. Hang up and Drive Last edited by mikemcE; 06-29-2019 at 08:31 PM. |
06-29-2019, 08:27 PM | #28 |
| Re: Which 1.9 Scaler? I really like what this truck has to offer. Its a neat looking truck.
06-30-2019, 01:24 PM | #29 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
| Re: Which 1.9 Scaler? Based on current offerings, I second this. This thing is a hell of a value. I would wait for the kit, as I like it has multiple length links and the metal transmission gears.
06-30-2019, 04:40 PM | #30 |
| Re: Which 1.9 Scaler? Vaterra Ascender F100 RTR or just the body on whatever truck ya get. My OG Va’Blazer is very capable and has only broken a couple front body mounts.
06-30-2019, 05:35 PM | #31 |
So many good trucks to choose from, so little money.
06-30-2019, 05:44 PM | #32 | |
The RTR electronics are better (not fantastic) than the average RTR electronics to boot. The stock tires are good and the included overdrive out of the box is a big advantage. Pick up some inexpensive Lipos off eBay or Amazon (I like Ovonics 3s 2200 packs), a good charger, and for under $450.00 you’re good to go. Leaves money in the budget for an aftermarket body and those wagon wheels too. | |
07-03-2019, 07:04 AM | #33 | |
One thing I noticed about the TRX is battery placement (center towards the rear, where the Enduro is up front going sideways. What are the pros and cons of each? | |
07-03-2019, 07:15 AM | #34 | |
The portals lift it for clearance, tradeoff is higher COG. I wont even mention the rummage sale rack and accessories up top. Ive always mounted batteries up front for better weight bias for crawling Hang up and Drive | |
07-03-2019, 07:24 AM | #35 |
| Re: Which 1.9 Scaler? Does it matter what size batteries? My batteries are all full size, 3s is 5000mah, 2s 5200mah-6500mah. Are shorties better?
07-03-2019, 08:43 AM | #36 |
| Which 1.9 Scaler?
That depends on use, the big batteries can give hours of trail time, but weight is one of those things you need, but not always where it ends up. I run 2200 small packs on some trucks, 4300 on others. And I run 850’s on my Bully. One of the nice features on the new Enduro, two battery trays! Hang up and Drive |
07-03-2019, 08:46 AM | #37 | |
RCC Addict Join Date: Sep 2017 Location: The OC
They're lighter. Some of the comp guys are running mini 2K to 2.5K mah packs placed strategically. Still get a couple of hour run time, and many will carry a spare or two in their pocket. It's all a matter of what you want out of your rig, what you like to do with it. Some are after power and speed with a brushless system, some like trail running, mudding, walking forest, some are into competition rock crawling under SORCA rules. You got a TRX4 to start? | |
07-03-2019, 10:37 AM | #38 | |
07-03-2019, 11:24 AM | #39 | |
I've been running Vaterra and Axial for a couple of years now, just got a TRX4 Sport kit, and the new AE Enduro. These newest ones are really cool rigs, both of them. You really can't go wrong with either. And both are an excellent platform to learn and grow from, performance is excellent on both, right out of the box. Plus both are available as kits if you want to build and/or customize from the get-go. The TRX is a little more proven, and is just an excellent, solid platform. The Enduro is brand new, but holds good promise. I've had the TRX out a couple of times and it is able to make all our tough lines on the rocks. My Enduro is so new I've yet to try the tough stuff, but that's coming this weekend. Preliminary testing shows great promise for it as well. Pick yer poison! Be forewarned...it's super addicting!! Have a great holiday! | |
07-03-2019, 01:39 PM | #40 |
Newbie Join Date: Mar 2017 Location: ESPAÑA
Although I would recommend Axial, the best car for you will be the one you buy in the future. Any prestigious brand that your colleagues recommend will satisfy you. Drive and enjoy."Pulgares hacia arriba"
Which 1.9 Scaler? - Similar Threads | ||||
Scaler, scaler, scaler...what happened to the crawlers? | Nubster | Newbie General | 30 | 05-04-2019 07:57 PM |
