08-16-2019, 02:48 PM | #41 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: New rig
My C2 rig is still a Vaterra. IMO the portal's ground clearance advantage outweighs the higher COG which can be offset with weighted hub covers and hardware. At least I find my basic TRX sport crawls nearly as well as my completely custom Vaterra. I haven't had enough time with the Enduro to know for sure, but it sure does well right out of the box! It's a great new platform. I don't think a stock SCX10ii is competitive any longer - nice platform to build from, but they really cheaped them out. |
08-16-2019, 03:03 PM | #42 | |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
| Re: New rig Quote:
08-16-2019, 08:34 PM | #43 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: New rig
After much deliberation, I'm still on the fence, but, this blew me away. Very impressive! This makes me want to buy one. Didn't know this truck was this capable. https://youtu.be/N_wRUu4EuJE Sent from my LM-G710VM using Tapatalk |
08-16-2019, 08:52 PM | #44 | |
| Re: New rig Quote:
Yeah, that guy is great. We do stuff like that all the time with our X4's. Do keep in mind that this accomplished only after a dedicated (extreme perhaps) weight reduction and CG lowering program. He has a separate video on how he did it. Well worth watching for any X4 owner looking for max performance. Not always pretty but definitely effective. Last edited by JC3; 08-16-2019 at 08:55 PM. | |
08-17-2019, 07:33 AM | #45 |
| Re: New rig
Once you get bitten by the rock crawling thing it can be very addicting. They all do well with some mods and good tires and foams. For many this is the entire game. The club comps are a blast.
08-19-2019, 05:49 PM | #46 | |
| Re: New rig Quote:
Yep! Last edited by Natedog; 08-19-2019 at 06:01 PM. | |
08-20-2019, 08:12 AM | #47 | |
| Re: New rig Quote:
Sent from my LM-G710VM using Tapatalk | |
08-20-2019, 09:21 AM | #48 |
| Re: New rig |
08-20-2019, 10:06 AM | #49 |
Newbie Join Date: Dec 2018 Location: US
| Re: New rig
Is it better to just get the trx4 or go cheaper with the sport package? Sent from my LML713DL using Tapatalk |
08-20-2019, 10:17 AM | #50 | |
| Re: New rig Quote:
Depends, always start with free/cheap mods and everyone has their level of hobby budget, I remember barely being able to afford a set of bearings back when everything came with bushings. | |
08-20-2019, 10:38 AM | #51 | |
| Re: New rig Quote:
08-20-2019, 10:51 AM | #52 | |
| Re: New rig Quote:
RTR is just that, a RTR - open it up and off you go. Modify or upgrade at will. While you're deciding you get to enjoy the truck and learn what it can do and also what you would like it to do. The Sport kit gives you the pleasure of assembling the kit yourself if you like to do that. However, before hand or during the build you'll need to figure out electronics, motor, receiver, etc and then install them. Not a big deal but does require some planning. My friend and I went with the Sport Kit. We always build our stuff and we knew full well that we would be upgrading the electronics and so we decided to spend the money on that. Either way, it's a win win! As Natedog said, "...always start with free/cheap mods." This is for sure true and important since a few simple free mods can really improve the stock kit's performance. | |
08-20-2019, 11:27 AM | #53 |
| Re: New rig
Out of all my rigs, I like the TRX4 sport the best I think. It just flat works. Very easy kit to build as well. It was my sixth truck, fourth kit, and not long after got the new Associated Enduro RTR. Like it too, but really, I think the portal axles have a lot going for them. Everything else between it and the Enduro are comparable. The under-drive gearing for the rear of the TRX have been backordered - in any case at some point you'll be able to match that feature with the TRX. Other than that, 550 motor, great chassis, good shocks and axles - it's all there. I added the SSD portal covers, they're 70 or 80 grams or so, down low, at the end of each end of the front axle. This crazy thing keeps up with my comp rigs, makes all the lines in our proving grounds. A little weight on the rear axles would help a bit as well, but really, weighting the front for climbs and traction give really good performance gains. My build thread here, and there are a couple more as well - scope them out and decide what YOU want. I didn't really care for the 'sport' no-name pickup, so mine got the Proline '68 Toyota LandCruiser. I don't have a lot of $$ in options on this one (yet), it's doing just fine with the portal weights and some decent tires and wheels. All that body and tires and wheels and all that is still in the box. A Holmes 550 Trailmaster motor and a hobbywing speed controller works great, about $60. Add the radio of your flavor. I'm running the cheapo DS3218 steering servo - works fine for what I do with it - $12-$18 depending on how long you want to wait. Built with the kit body it has a ton of accessory options, and performance is excellent. 66 Toyota Land Cruiser FJ40 - TRX4 |
08-20-2019, 11:34 AM | #54 | |
| Re: New rig Quote:
New rig - Similar Threads | ||||
Tonka tow rig 4wd conversion recovery rig and trailer | NissanNut | 2.2 Scale Rigs | 4 | 02-13-2015 02:36 PM |
