08-18-2019, 10:52 AM | #1 |
Quarry Creeper Join Date: May 2016 Location: Nässjö
| Need suggestions on aftermarket chassi, no specific class rules
Today I have a toyzuki v2 with a 2.5 transfer case and 1.9 tires. I run 3s 500mah with a revolver 1800kv. As for class rules here in Sweden there basically are non. I want a truck to be able to run the regular 1/10 body. I would prefer it with some over drive. What else is there then toyzuki that can do that using ar44 axles. Skickat från min iPhone med Tapatalk |
08-18-2019, 06:49 PM | #2 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: Need suggestions on chassi, no specific class rules |
08-18-2019, 10:28 PM | #3 | |
| Re: Need suggestions on chassi, no specific class rules Quote: Where is the overdrive option? Skickat från min iPhone med Tapatalk | |
08-19-2019, 12:48 AM | #4 |
Quarry Creeper Join Date: Jun 2007 Location: Loiret, France
| Re: Need suggestions on aftermarket chassi, no specific class rules One of my cars has hillkiller v4 chassis with axial tranmission, I think I will replace it with enduro sendero transmission to have over / under drive.
08-19-2019, 08:27 AM | #5 |
the over/underdrive is in the axles or transmission/tcase or both the chassie dosent have anything to do with it you do need a skid to fit the trans so atmost you might need to drill some holes in your new chassie |
08-20-2019, 10:04 AM | #6 | |
| Re: Need suggestions on aftermarket chassi, no specific class rules Quote:
I said I run a toyzuki v2. I guess it would be understood that I want a solution similar to that, not a diy solution. I don’t believe I said rails only. The only possible overdrive through ar44 axles are just 11%. Skickat från min iPhone med Tapatalk | |
08-20-2019, 10:17 AM | #7 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
For my understanding is that if you take out the 2.5v t-case out of the toyzuki chassis then no od/ud. So really its the t-case not the chassis. Any chassis is capable of od/ud with the right parts. In Harley's new video he ran a vs4-10 pro with a portal rear axle and is running with gear reduction about 20% overdrive. So combo of parts can achieve goal wanted. Just a thought. |
08-20-2019, 10:31 AM | #8 | |
just rember pics or it dident happen | |
08-20-2019, 02:14 PM | #9 | |
Toyzuki are meant to be run as a package if you want the full benefit. I would not say just the rails being better then anything else out there. Motor are mounted upfront which require you to use a transfer case. Using the 2.5 case give me 44% or something like that and 2.0 case are 30% something. 20% would be to little for me. Now my turning radius are so much smaller I would need 4ws with 20% Skickat från min iPhone med Tapatalk | |
08-20-2019, 02:56 PM | #10 |
| Re: Need suggestions on aftermarket chassi, no specific class rules https://thecrawlspaceonline.ecwid.co...e-3-p140660080 There is this chassis, but I believe the toyzuki chassis package really is the only one as a kit of what I think your looking for. My next question is why can you run a 1/10 truck body on your toyzuki chassis? |
08-24-2019, 06:46 PM | #11 |
It sounds like your saying a chassis that uses standard axial skid plates and all the various transmission that can bolt up to it is too much work to piece together. That pretty much leaves you with builders kits and toyzuki. Are you also considering sporty chassis? Because you can mount a 1/10th body to anything. Sent from my SM-N950U using Tapatalk |
08-25-2019, 09:17 AM | #12 | |
I can consider a sporty but not familiar with those. As long as I can fit a axial ranger body on it I’m ok with that. Skickat från min iPhone med Tapatalk | |
Need suggestions on aftermarket chassi, no specific class rules - Similar Threads | ||||
my rig specific upper/lower link combos questions/suggestions | sawhead | Axial SCX-10 | 5 | 01-06-2014 04:41 PM |
Specific instructions / suggestions for Axial Night Vision (NVS) and Rubicon? | Greg2K6 | Axial SCX-10 | 1 | 10-30-2013 07:04 PM |
Specific tuber rules clarification | Dumptruck | General Crawlers | 2 | 04-17-2008 01:09 PM |
