09-06-2019, 11:35 AM | #1 |
| Portals, overdrive, reversed transmissions, and flipped ring and pinions...
Looks like we have the beginnings of a trend here, some new ideas and some old. With more manufacturers joining the fray and kit-bashing reaching a new level, I thought some additional discussion might be interesting. Harley released a video that covers using multiple options combined together for increased performance here: |
09-06-2019, 11:44 AM | #2 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Portals, overdrive, reversed transmissions, and flipped ring and pinions...
Yes, I saw that video this morning. looks interesting. Sent from my LM-G710VM using Tapatalk |
09-06-2019, 12:07 PM | #3 |
When I first heard about Harley using portals in the rear only, I was toying with the idea of assembling my VS410 chassis with an Enduro transmission and SSD axles. Then I got pretty excited about assembling a variation on his build, continuing to use (more affordable for me) SSD parts, such as their rear portal axle. But I realized that I would have to do some serious figuring as to how to gear everything to work properly and not have too much overdrive or an axle being rotated the wrong way. For now I have put that project on the back burner, but the concept really interests me - I hope to see some other parts combined and tested and results posted. |
09-06-2019, 12:30 PM | #4 |
Nice to see sthcale catching up to comp in less than the 10 year average it has been. I had to chuckle when he mentioned the OD gears came from supershafty and not that they are a competitor brands gears. If VP would make an OD gear set the market wouldn't be forced to use others. |
09-06-2019, 12:57 PM | #5 | |
| Re: Portals, overdrive, reversed transmissions, and flipped ring and pinions... Quote:
09-06-2019, 01:04 PM | #6 | |
RCC Addict Join Date: Nov 2014 Location: Nowhere
09-06-2019, 01:27 PM | #7 | ||
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
https://www.rpphobby.com/product_p/ssd00284.htm I might do it just to show how easy it would be. I think, very little modding to make it work. And don't let the extra width scare you away, that could be fixed very easily! Just some thing to think about! And take a look at the price difference. Just saying. Ernie | ||
09-06-2019, 01:34 PM | #8 | ||
Swap that center out for their diamond style for an additional $13 or so and you have what you're after. I think I read somewhere that 15/15 gears are available too. | ||
09-06-2019, 01:44 PM | #9 |
| Re: Portals, overdrive, reversed transmissions, and flipped ring and pinions... |
09-06-2019, 02:20 PM | #10 | |
Ernie Last edited by CODYBOY; 09-06-2019 at 07:17 PM. | |
09-06-2019, 02:37 PM | #11 |
I don't think the extra width is really an issue on the rear because assuming you run SLW type hubs you could always just get the narrowest hub and a positive offset wheel (CI 6 bolt for example) to compensate, so it's a lot easier to fix compared to the front. I also don't think it's too much of a challenge with the correct parts, but as shown if you're trying to work with an axle/3rd member that can't be flipped, and both axles and transmission having overdrive, you're going to have a fun time.
09-06-2019, 03:31 PM | #12 |
It was a fun project, nothing crazy difficult to achieve with several different combinations of parts available on the market. It was also just a good excuse to make a video on calculating overdrive ratios.
09-06-2019, 03:47 PM | #13 |
09-07-2019, 10:35 AM | #14 | |
RCC Addict Join Date: Oct 2014 Location: UK
I will reply soon | |
09-07-2019, 03:09 PM | #15 |
Quarry Creeper Join Date: Jan 2014 Location: Logan
I like this subject, I've built a rock buggy with everything mentioned but have yet to show it off. It uses a losi night crawler transmission in front that allowed me to drop the motor right next to the front differential that is then routed to a modified cheeseburger transmission, the cheeseburger allowed a slight amount of underdrive to the front axle, yes don't be confused I said underdrive, in the front I've used a vanquish vs4-10 front axle, the offset allowed the motor to be dropped low. Out back I'm using a vanquish portal rear axle, this overall gave me overdrive in the front due to the difference in gear reduction. The cheeseburger transmission reverse rotates the drive shafts allowing no mods needed to be made to either axle for proper direction of drive. So in short the truck has overdriven front, reverse rotation and portal rear axle while all maintaining a front mounted motor. If anybody is interested I can post pictures.
09-07-2019, 03:14 PM | #16 | |
Ernie | |
09-07-2019, 03:24 PM | #17 |
09-07-2019, 06:06 PM | #18 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Interesting, Fast fast post up | |
09-08-2019, 12:12 PM | #19 |
09-08-2019, 12:18 PM | #20 |
Portals, overdrive, reversed transmissions, and flipped ring and pinions... - Similar Threads | ||||
HELP need ring and pinions | MatrixTech | Tamiya TLT Crawlers | 4 | 04-05-2007 11:03 AM |
I Need Ring And Pinions For A Tlt | Flex | Tamiya TLT Crawlers | 6 | 02-06-2006 11:39 AM |
