09-28-2019, 05:12 PM | #21 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
| Re: Kyosho rampage pro - no moa!
The Ssd diamond looks perfect under there. Their wraith trans would probably give us the gear ratio needed for high speed. That or a Yeti trans maybe. It's killing me. I want mine now!
09-28-2019, 05:28 PM | #22 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
This is the best thing I've seen today. Now I want one.
09-28-2019, 06:35 PM | #23 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Man that looks awesome fxman! Axle swap n those tires really set it off. I think it looks way better than the udr lol Sent from my SM-J327VPP using Tapatalk |
09-28-2019, 07:11 PM | #24 |
Quarry Creeper Join Date: May 2013 Location: no-water-no-trees-country
Had to take my Wraith apart. Held in place by just one screw for now I mounted the trans behind the battery holder. This thing hauls ass now! All that needed to be done is - a scx10 rear axle - longer upper links - scx10 trans I didn’t want to cut the inner cage so I raised it slightly for it to clear the trans. Next task is a trans mount. What could I use to fill the gap underneath it? Custom piece out of a plastic cutting board maybe? Or just drill four new holes in the bottom and use spacers? Sent from my iPhone using Tapatalk |
09-28-2019, 07:12 PM | #25 |
Oh, and thanks guys for the support here Sent from my iPhone using Tapatalk |
09-28-2019, 07:28 PM | #26 |
Son of a b****!😮 That’s awesome! Know anyone with a 3D printer? If not, I’m sure you could get away with making spacers from a section of cutting board and perhaps a couple longer bolts? Subscribed!👍🏼 |
09-28-2019, 07:43 PM | #27 |
Quarry Creeper Join Date: Apr 2017 Location: Melbourne Australia
I'm about to grab one of these and will want to do this conversion. I have a 3d printer so will design a trans mount!. Sent from my LYA-L09 using Tapatalk |
09-29-2019, 03:26 AM | #28 |
Looks great. Some printed parts would definitely help. How is the pinion angle. Think I'm gonna use a F9 10.2 axle for the higher pinion position. Great work done here.
09-29-2019, 09:30 AM | #29 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
| Re: Kyosho rampage pro - no moa! |
10-02-2019, 01:59 PM | #30 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
Epic build!! I will say that motor on axle is what kinda pulled me into buying the Rampage. Less maintenance and very robust and having the weight over the rear tires is key for a model is that already tail happy with a lot of suspension travel. This chassis is lightweight and need all the weight you can get over the rear tires and i think a smart design from Kyosho. I agree it does't look the best but for a RWD Basher it's a great setup. |
10-04-2019, 07:21 AM | #31 | |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
| Re: Kyosho rampage pro - no moa! Quote:
But if scale looks are the priority, this is a great improvement. Very nice! | |
10-04-2019, 11:02 AM | #32 |
Quarry Creeper Join Date: Jul 2015 Location: Moncton
really awesome looking combo.
10-17-2019, 08:27 AM | #33 | |
I need to get a better drive shaft and that trans further down - or like you said, the axle pinion up I guess. | |
10-17-2019, 09:02 AM | #34 |
RCC Addict Join Date: Oct 2014 Location: UK
Nice, I'm totally going to copy this build. Thanks |
10-17-2019, 03:14 PM | #35 |
Pebble Pounder Join Date: Aug 2019 Location: Redlands, CA
So supremely cool what you’re doing here, man. I just pulled out the box of unsensored brushless stuff to see to see if there’s anything in there that wouldn’t overwhelm your drivetrain. Could donate an old but fresh Hobbywing 10.5T or Castle 4600, but looks like you might have that part already figured out?—it’s here if you need either one. Thanks for charting a truly original course and good luck. It’s a great read.
10-18-2019, 07:33 AM | #36 | |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
10-19-2019, 11:16 AM | #37 |
Newbie Join Date: Nov 2018 Location: Porterville
Amazing build I just finished mine great fun to drive I already want another one and do a custom build.
10-22-2019, 07:05 AM | #38 | |
I certainly don't want to discourage anyone from trying the conversion. If you were running reasonable power levels and driving in a scale manner, these "issues" might not even be noticeable. OP seems to be happy with his, and he's the expert in the room. Last edited by TooOldForThis; 10-22-2019 at 07:21 AM. | |
10-22-2019, 08:20 AM | #39 | |
Have you converted your Rampage to a solid axle? Quote:
10-22-2019, 03:00 PM | #40 |
| Re: Kyosho rampage pro - no moa! No, maybe I should have clarified that. I'm comparing the way a non-converted Rampage drives to the way other traditional solid axle trucks drive (specifically the Losi Rey and Yeti Score). So I'm assuming a converted Rampage would pick up the same handling quirks common to the others. I could be wrong. Apologies to the OP if this is derailing the thread. |
Kyosho rampage pro - no moa! - Similar Threads | ||||
Kyosho outlaw rampage pro | soze | Chit Chat | 202 | 09-04-2021 07:19 PM |
NEW Kyosho Outlaw Rampage PRO 2WD Kit - In Stock! | RPP Hobby | RPP Hobby | 0 | 08-05-2019 10:03 AM |
Pre-order NOW! The NEW Kyosho Outlaw Rampage PRO 2WD Kit - Pre-order Now! | RPP Hobby | RPP Hobby | 0 | 05-09-2019 05:06 PM |
Rampage MT PRO ATV | Richalaska | Videos! | 3 | 03-10-2016 05:43 AM |
Kyosho Outlaw Rampage Truck | grizzlypaugh | Non Crawler RC's | 5 | 04-11-2012 04:14 AM |
