11-09-2019, 10:53 PM | #21 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: I need BIG help choosing the highest clearance axles without going to portals. Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-10-2019, 01:35 AM | #22 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
A skid is going to reduce your clearance that you are looking for. If your looking for weight down low I'd swap out plastic axle parts for brass pieces.
11-10-2019, 10:25 AM | #23 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
Yes they make beef tubes, brass diff covers, brass knuckles......and they are not cheap. I have always ran a double wrap of lead wheel weights in the front wheels. Never had an issue with rotating mass. That is around 128g or 4oz in each wheel A few years back I did a test and added different amounts to lead to the axle to see if it would make any improvement. I didn’t notice any improvement. I even added weight to the chassis and it got worse I came to the conclusion that weight in the front is more for balance it keep it nose heavy. Now imo tires seem to work better when they run at a lower pressure like soft foam letting the tire bulge. When you have firmer foam maybe more weight can help. I would rather change the foam |
I need BIG help choosing the highest clearance axles without going to portals. - Similar Threads | ||||
3racing high clearance knuckles(portals) - where to buy | Slowkrawl | Axial AX-10 Scorpion | 10 | 10-18-2012 10:21 PM |
Another take on high clearance axles.. | guest | Tamiya Clod Buster | 5 | 01-09-2008 04:01 PM |
high clearance axles | kacz7895 | Tamiya Clod Buster | 6 | 07-18-2007 09:35 AM |
1:1 high clearance arched axles | STANG KILLA SS | Chit Chat | 16 | 12-07-2006 09:46 PM |
SOOOOOPER High Clearance X Factor Axles | DirkDigler | General Crawlers | 12 | 08-02-2004 07:39 PM |
