Thread: I need BIG help choosing the highest clearance axles without going to portals.
Old 11-07-2019, 12:13 PM   #1
Default I need BIG help choosing the highest clearance axles without going to portals.
I don't have a lot of experience yet with all the crawlers. I need the latest info on witch straight axles gives the highest clearances under the punkin.
Tim3 is offline   Reply With Quote
Old 11-07-2019, 06:05 PM   #2
CODYBOY's Avatar
Default Re: I need BIG help choosing the highest clearance axles without going to portals.
I think the ascender has some of the best clearance on the scale market. Having said that it doesn't mean it is the best performer.
Ernie
CODYBOY is offline   Reply With Quote
Old 11-07-2019, 06:23 PM   #3
SDD Diamond Pro would be pretty close to highest clearance I think. It would deffinately be the smoothest design with least catch points.
nedmo is offline   Reply With Quote
Old 11-07-2019, 06:29 PM   #4
If your not going portals it's just a few mm difference between all made. Get a strong set and let em drag.
donny8594 is offline   Reply With Quote
Old 11-07-2019, 06:32 PM   #5
I agree, just let it drag.
RC4WD make these raised pumpkin axles, I dont know if I'd go as far as to recommend getting them as they aren't know for their durability, aren't cheap I've also never seen them out in the wild. https://store.rc4wd.com/Leverage-Hig...10_p_5321.html
A bit more info on the Ascender axle, its the smallest pumpkin out there but the gearing inside produces the most torque twist out of all of the crawler axles.
You could gain extra clearance at the pumpkin by simply running taller tires.
We know you're after the most clearance but beyond that what are you building? Knowing that would help us to guide you better.
HumboldtEF is online now   Reply With Quote
Old 11-07-2019, 06:40 PM   #6
I considered those for a few minutes...probably a few more than I should have. After reading several reviews, I knew to avoid them.
~ More peace, love, laughter & kindness would make the world a MUCH better place
Panther6834 is offline   Reply With Quote
Old 11-07-2019, 06:47 PM   #7
I agree with CODYBOY, the Ascender has good clearance at the pumpkin for a straight axle. I added Duratrax 1.9 Deep Woods tires for extra clearance and use it at the local comps. It performs quite well head to head with the more expensive rigs. I also agree with the others, let it drag!
mv1985 is offline   Reply With Quote
Old 11-07-2019, 08:17 PM   #8
The other way to get more effective diff housing clearance is run narrower axles or wheels with more offset...
There are some wheels out there that can be run reversed, with their hubs flipped.
Some of the SSD steelies, Boom Racing steelies, and GearHead RC wheels.
durok is offline   Reply With Quote
Old 11-07-2019, 11:10 PM   #9
You can get bigger tires like the hyraxes to raise the pumpkins.
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Old 11-08-2019, 12:01 AM   #10
But remember, larger diameter means more, thus more weight, thus more rotational mass. That's why, in building up my second Capra, I'm going with SSD wheels, instead of Vanquish wheels (which I installed on the first Capra)...plus I'm sticking with portals.
Old 11-08-2019, 04:32 AM   #11
I just spooned some 1.9 Deep Woods on to the refresh/rebuild of my Barrage/Axial hybrid build. I was also looking for a bit of additional clearance and the taller aspect of the Deep Woods caught my eye. Looks like I gained about 3.5mm of clearance.
Anyway, how do they do in the comps?
mewalsh100 is offline   Reply With Quote
Old 11-08-2019, 07:59 AM   #12
10.2 axles in plastic, pick the best lines you can and let the diff drag. It wont hurt ya.
gottorque is offline   Reply With Quote
Old 11-08-2019, 09:56 AM   #13
Originally Posted by hobbyjumper View Post
Not sure why no one has mentioned them, but the Axial AR44 has hypoid gearing specifically there to lessen the pumpkin.
AR44's do have the nice feature of the high pinion axle, the ring gear is still in the same place so the pumpkin is actually no higher, only the pinion sits higher.
Old 11-08-2019, 09:57 AM   #14
Natedog's Avatar
Vaterra Ascender.
Yep, sometimes they're just going to drag. Pass on the RC4WD axles due to lower quality metal, parts availability and price.
Agreed, just remember smaller tires generally sidehill better.
Yes, narrow track is great idea!
Old 11-08-2019, 10:15 AM   #15
WOW...! I am really grateful for all of the responses from you ALL !
You guys rock !!!!!
This is what I needed to help me make the decision where to go in my happy buying cart... lol
Its going to be 1.9 rig build. LET IT DRAG THEN !
Now who makes a solid Axial AR44 in aluminum ?
Old 11-08-2019, 11:16 AM   #16
Only one (of quality...no cheap Asian imports) I'm aware of is Vanquish.
Old 11-08-2019, 02:02 PM   #17
Tires really stick to the rocks, usually finish in the top 5 Class 2. Clearance at the pumpkin with the Deep Woods is 44.45mm. Considering the price, the Ascender and the tires are a good deal, IMO.
Old 11-08-2019, 02:17 PM   #18
I'm curious about how the new JConcepts Landmines will compare against the Deep Woods & Hyrax. For those interested (since the info doesn't seem to be published anywhere, including on JConcepts' own website), the Landmines diameter is 4.74" (I called them, and someone actually measured them for me).
Old 11-08-2019, 06:22 PM   #19
Yeah, they're a good Bunch over there at jconcepts. Very friendly, and very helpful people that work there. I have nothing but good things to say about jconcepts.
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 11-09-2019, 10:40 PM   #20
Can’t say much for other axles but I like the ar44. The pumpkin is much smaller than original scx10 axle. If you get the version that has universals the steering is fantastic. Numerous options for overdrive gears. Not a big fan of metal housings. Great for weight but they don’t slide over rocks like plastic
dirtman71 is offline   Reply With Quote
I need BIG help choosing the highest clearance axles without going to portals. - Similar Threads
3racing high clearance knuckles(portals) - where to buy Slowkrawl Axial AX-10 Scorpion 10 10-18-2012 10:21 PM
Another take on high clearance axles.. guest Tamiya Clod Buster 5 01-09-2008 04:01 PM
high clearance axles kacz7895 Tamiya Clod Buster 6 07-18-2007 09:35 AM
1:1 high clearance arched axles STANG KILLA SS Chit Chat 16 12-07-2006 09:46 PM
SOOOOOPER High Clearance X Factor Axles DirkDigler General Crawlers 12 08-02-2004 07:39 PM
