11-04-2019, 07:10 AM | #1 |
Newbie Join Date: Nov 2019 Location: Santiago
| Ideal size of shock absorbers for crawlers
Hi guys, I have a mst cfx-w and I want to change the plastic shock absorbers as standard for aluminum ones. My doubt is in the ideal size for these, since very long ones will lift the center of gravity quite a bit, but I want some that have a longer distance than the original 70mm. I have thought about installing about 80 or 90 mm, what do you recommend? If someone already did what is the performance? Thanks in advance and greetings
11-08-2019, 12:03 PM | #2 |
Newbie Join Date: Nov 2019 Location: Alger
| Re: Ideal size of shock absorbers for crawlers
tiffer rear springs would help with torque twist. On scale crawlers I almost always run the same springs weights on both rear springs, but it is common to see 2.2 comp crawlers use a stiffer rear spring only as a replacement for the rear spring opposite the front tire that lifts during torque twist. There is no reason why you couldn’t add one slightly stiffer rear spring. Sarkari Result Pnr Status 192.168.1.1 Last edited by clarc; 11-09-2019 at 06:08 AM. |
Tags |
crawler, mst, mst cfx-w, shock absorber |
Ideal size of shock absorbers for crawlers - Similar Threads | ||||
Ideal size of shock absorbers for mst cfx-w | estbx | Max Speed Technology CFX | 3 | 11-08-2019 12:26 PM |
MST CFX... Out with the old in with the CFX... | Old n ratty | Max Speed Technology CFX | 24 | 01-13-2019 08:57 AM |
New G-Made RSD Shock Absorbers | LSXGMC | General Scale Talk | 21 | 01-22-2017 02:08 AM |
Mst cfx-w | Rcdood | Chit Chat | 50 | 01-11-2017 07:55 AM |
