Thread: Acrylic chassis rails
Old 12-02-2019, 09:05 PM   #1
Default Acrylic chassis rails
Hi all,
I want to 3d print this for fun but the chassis rails won't fit on my bed.
A mate of mine said he can laser cut me the rails but he is only allowed to use acrylic or wood at his work.
He said he can do 4.5mm thick acrylic..
Has anyone got any experience/have any indication if 4.5mm acrylic would be rigid enough?
https://www.thingiverse.com/thing:3340951
Sent from my Phone 2 using Tapatalk
Spunkybob is offline   Reply With Quote
Old 12-02-2019, 09:14 PM   #2
Default Re: Acrylic chassis rails
Acrylic will crack. If he can do g10 that's good stuff. It's reinforced and compressed resin.
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Old 12-02-2019, 09:15 PM   #3
Wood would be better then acrylic probably.
Old 12-02-2019, 09:16 PM   #4
Honestly, I would NOT recommend it. It's not a matter of whether, or not, they are rigid enough. Acrylic is a fragile material, and could crack, or shatter, fairly easily. Years ago, I worked in the Plastic industry, so I know of what I speak. now, there is the possibility that lexon, or any generic cast polycarbonate, could work, but I'm not going to go so far as to say it's "will" work.
~ More peace, love, laughter & kindness would make the world a MUCH better place
Panther6834 is online now   Reply With Quote
Old 12-02-2019, 10:21 PM   #5
Thanks guys.
I'll see if someone local can print it
Old 12-02-2019, 10:45 PM   #6
I used 1/8" polycarbonate for chassis rails. It works but requires a lot of reinforcing to make rigid. It can work, if designed right.... I wouldn't touch Acrylic.
lonleycreeper is offline   Reply With Quote
Old 12-03-2019, 03:05 AM   #7
+1 on acrylic being way too fragile for crawler truck frame rails. Acrylic is good for fake glass, that's about it.
fyrstormer is offline   Reply With Quote
Old 12-03-2019, 05:14 AM   #8
What types of exotic woods do you have access to?
Brake Weight is offline   Reply With Quote
Acrylic chassis rails - Similar Threads
Acrylic Chassis? amorton94 General Crawlers 13 04-01-2009 10:48 AM
Losi Custom Tvp Chassis Made from Acrylic willashcroft Losi Mini-Rock Crawler 3 02-23-2009 04:36 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
