02-03-2020, 09:46 AM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Opinions please
I want portals, so should i buy the new redcat axe, a trx4 chassis kit, OR the currie VP portals? Which would you choose? |
02-03-2020, 09:52 AM | #2 |
Newbie Join Date: Jan 2020 Location: US
| Re: Opinions please
I have a trx4 and I absolutely love it. I had such a fun time building it the only thing I would do is throw the locking riffs and get the traxxas diff spools tra8297. I havent found a place I need open diffs. the stock servo is kind of trash so you wanna get that upgraded asap, especially if you're gonna get the traxx. the two speed tranny is really helpful along with the cruise control on the transmitter.if you're going full speed and turn it will just tip right over so theres that. but nonetheless, I absolutely love it. Sent from my SM-N960U using Tapatalk |
02-03-2020, 09:54 AM | #3 |
| Re: Opinions please
the portal axles also help so much for what I've experienced. message me for any other questions, I'll be happy to assist you! Sent from my SM-N960U using Tapatalk |
02-03-2020, 10:15 AM | #4 |
Newbie Join Date: Feb 2019 Location: Mynm
| Re: Opinions please
I would strongly recommend trx4! Sent from my SM-N975F using Tapatalk |
02-03-2020, 10:17 AM | #5 |
| Re: Opinions please |
02-03-2020, 10:23 AM | #6 |
| Re: Opinions please
I think you'd have to be insane to choose the Redcat Gen8 over a TRX-4. The TRX-4 has already proven to much tougher and less problematic. The TRX-4 is great. VP is a different price level altogether. |
02-03-2020, 10:51 AM | #7 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Opinions please
I got the trx4 unassembled Sport kit so I could choose my own Electronics. Out of the many kits that I've built, it was by far the easiest to assemble. I absolutely love it! Mine is a pure crawler. I have no need for the 2 speed model. Sent from my LM-G710VM using Tapatalk |
02-03-2020, 10:55 AM | #8 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: Opinions please
I'd only ever pick Redcat if it was the only option, otherwise TRX-4 every time. VP only if you really like staring at your axles while crawling.
02-03-2020, 11:07 AM | #9 |
| Re: Opinions please
Heck, you can get a whole TRX 4 sport RTR for less than it would cost to buy the Vanquish portals front and rear by themselves Sent from my LM-G710VM using Tapatalk |
02-03-2020, 03:33 PM | #10 |
Pebble Pounder Join Date: May 2019 Location: Henderson, NC
| Re: Opinions please
I'm relatively new to all this, I don't compete I just play, and I also love my TRX4 - I have the RTR Blazer. I don't see the extra money in the Redcat Axe edition. But my brother bought a regular Redcat Gen8 Scout and it's a nice truck as well. Can't switch gears, can't lock/unlock diffs, and no cruise control - but with driver finesse at the wheel the Gen8 will crawl as slow as my TRX4 and follow same lines, and at wide open my TRX4 in 2nd gear is just very very slightly faster. I can't say anything bad about the regular Redcat Gen8 Scout at all. So (to me anyway) there's really not much advantage in the TRX4 - some days I love the little bells/whistles of my TRX4, other days I think I should've saved that $200 and got the Redcat Scout. |
02-03-2020, 04:33 PM | #11 |
| Re: Opinions please
That's what makes the trx4 sport a good choice. Same (lack of) features as the gen8, similar price, but then you have the benefits of the much more expansive aftermarket support. I've owned my share of redcats and had reasonable luck with them, but between a gen8 and a trx4, I'd absolutely go trx4. That said, is the Capra out of the question? Or I guess the bigger question is: what are you looking to do/build out of it? |
02-04-2020, 06:18 PM | #12 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
| Re: Opinions please
Redcat plastic is not strong enough. Portal gears are weak. The money spent to get them even close to durable, would be better spent on another brand of portal axles. They would not be on my list at all. Great starter truck but not durable. That's my reason for getting rid of the Gen8
02-04-2020, 08:48 PM | #13 |
Rock Crawler Join Date: Jul 2013 Location: california
| Re: Opinions please
I love my trx4, it is very reliable. The only thing the trx4 needed is more weight down low. Why didn't you include the capra? The capra also has portals and has been more capable than the trx4. Both are great trucks. Side note also what about the ssd portals or the new supershafty aluminum capra axles? Just giving you more options. |
02-05-2020, 07:29 AM | #14 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Opinions please
I won't argue that the TRX4 is stronger/better than the Gen8, because I believe that it is, but I will argue that the Gen8 isn't as problematic as some people make it out to be. The Gen8 did have some weak points, which were mentioned here: axle housings and the upper portal gears. Both of these have been addressed by Redcat, and are being incorporated into the newer trucks, including the Axe edition. The housings are re-designed and have double-shear shock mounts now. The axles & upper portal are redesigned to be substantially stronger. Redcat also offers chromoly shafts and gears as an additional upgrade. When Redcat first released the updated parts, I bought them, and still haven't installed them, because I still haven't broken the original parts yet, even though most of my driving is on 3S. If you don't treat this truck like a Stampede and huck it off a bunch of jumps, or do dumb stuff like yank the throttle when the wheels are bound up, your chances of actually breaking these parts is somewhat low. Ultimately, it's my opinion that the durability of the Gen8, while not necessarily at the same level as the TRX4, is perfectly adequate for all but the most abusive users, and if the Gen8's other features appeal to you (cosmetics, price, etc), then I wouldn't shy away from buying one. I'm very happy with mine, and I haven't yet had any remorse over buying it instead of the TRX4. |
02-05-2020, 09:04 AM | #15 | |
Pebble Pounder Join Date: Aug 2017 Location: Mesa
| Re: Opinions please Quote:
I'm very happy with my Gen8 & while I do like the TRX4, I don't really feel the need to get one. The Gen8 performs just as well or better than any of the other brands out on our local trails. | |
02-05-2020, 07:20 PM | #16 |
Rock Stacker Join Date: Jan 2020 Location: OH
| Re: Opinions please
Trx4 blazer is the one id keep if I sold them all.
04-19-2020, 07:51 AM | #17 |
04-19-2020, 09:33 AM | #18 |
| Re: Opinions please
I would add that of all the portal axle kits currently on the market, the TRX4 has far more aftermarket support. There are a number of all metal axle housing options for the TRX4 for not a lot of money up to a lot of money if you choose. That said, I have a question for "damnitbubbles". How do you drive that truck with tracks on the rear and tires on the front? The drive ratio difference front to rear is so dramatic that that thing has to be dragging the rear or slipping the front or both in the extreme. I'm just guestimating here but if you divide the diameter of the front tire lets say 4.7" by the diameter of the rear drive sprocket lets say 1.5" that's a drive ratio of 3.13:1 front to rear. By comparison, using the TRX4 OD/UD ring and pinion gears gives you a 1.23:1 ratio front to rear. The bottom line is that is an extreme OD/UD setup. Last edited by Inspector86; 04-19-2020 at 10:22 AM. |
04-19-2020, 12:38 PM | #19 |
Quarry Creeper Join Date: Jun 2007 Location: Loiret, France
| Re: Opinions please
MST CFX-W is not available where you live ?
04-19-2020, 12:55 PM | #20 | |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
Opinions please - Similar Threads | ||||
Need some opinions | Briguy-01 | Axial Wraith | 10 | 02-12-2013 09:58 PM |
opinions please | gofaster427 | General Scale Talk | 5 | 09-17-2012 08:04 AM |
any opinions? | sabo_traxxas | Traxxas Crawlers | 4 | 12-14-2007 11:48 AM |
i need opinions | TeamDeweyRacing | Tamiya Clod Buster | 7 | 01-05-2007 10:52 PM |
Your opinions | Unholy | Chit Chat | 7 | 05-31-2006 02:16 PM |
