Thread: Vanquish machined rod ends.
Old 06-02-2020, 08:51 PM   #1
Default Vanquish machined rod ends.
They come in black and clear. Like all vanquish stuff they are pricey, but if you are a rod end killer they will be they will get you through the end of the day.
Ghonda99 is offline   Reply With Quote
Old 06-22-2020, 08:24 PM   #2
Default Re: Vanquish machined rod ends.
Do these offer any advantage over plastic rod ends or are these just for bling?
NeoPyro is offline   Reply With Quote
Old 06-22-2020, 08:39 PM   #3
Apparently you can adjust the tension on the ball as it wears and as mentioned above if you're a rod end killer these should hold up better.
HumboldtEF is offline   Reply With Quote
Vanquish machined rod ends. - Similar Threads
will jato rod ends fix my ti rod problem? J-Fish Axial XR10 8 03-19-2013 06:56 PM
4mm rod for Revo rod ends rcjackson0926 Axial XR10 11 03-03-2011 01:50 PM
Drilling Holes into Delrin rod for rod ends FDAapproved Losi Mini-Rock Crawler 10 02-13-2009 03:44 PM
