07-13-2021, 09:03 AM | #41 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Element Enduro Builder's Kit... 2 Quote:
The Enduro axle is a bad design. it is low pinion. Low pinion = less clearance and more torque twist. There is no good reason to waste money upgrading that axle. The Enduro could probably be the best RTR if they would just update their axles. | |
07-13-2021, 01:03 PM | #42 | |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
07-13-2021, 01:50 PM | #43 |
| Re: Element Enduro Builder's Kit... 2 the pinion is spinning at a decent speed. Not sure how bushing would work. I would think there would be a lot of friction and then heat.
07-13-2021, 02:07 PM | #44 |
Pebble Pounder Join Date: Nov 2009 Location: Newmanstown, PA
It would require new molds, but the element axle housing could be flipped and made to be high pinion - as the differential can be reversed in the housing already for front or rear axle use. (This is why it has the "stop sign" shape that some people aren't a fan of). Or make an axle housing with a bolt on truss for the upper links that can be oriented for high or low pinion, the shock/lower link mounts can already be flipped. Or just literally make a high pinion housing only - flipping the location of the pinion around Or quite possibly the above idea is stupid and I have no idea what is going on. This is going entirely on the idea I have in my head that the front and rear housings are the same, and the differential can be reversed within said housing. |
07-13-2021, 02:12 PM | #45 | |
Or just buy on of many AR44 (or other axles) already made and supported. | |
07-13-2021, 02:40 PM | #46 |
| Re: Element Enduro Builder's Kit... 2 I resorted to bushings a few years back for the axles pinions and front c-hubs. Probably triple the life of the bearings i seemed to be replacing a couple times a year. I'll use Bearings in race buggies, but i find bushings to be much better suited for crawlers that see high load and mud/water more often than other RCs. I'll have to grab some 10x5x4 bushing for the Element....sucks they don;t use the standard 11x5x4
07-13-2021, 03:51 PM | #47 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
I think they did a good job with this kit. Only increasing price $10 is nice after seeing other brands with bigger increases (‘21 bronco trx4 for example). The delrin pivot balls have my attention. I like the look of the bronze shocks more than the blue, don’t mind plastic caps but would have loved for black aluminum caps here. High clearance links are a nice touch/trade off for the 3 wb options. Are the trans gears plastic now? If so that lightens up the transmission a tad. Quote:
Between the small pinion bearing, the availability of replacement ring and pinion gears, and the pinion design itself, I’m with the others on just swapping to ar44s if you’re looking to upgrade much. The BTA steering is neat but not a deal breaker to lose in an axle swap. With that being said, I do hold out hope that Ssd may make an axle upgrade here. They can probably use the same tubes from the pro44 and redesign the Diamond center section to work with the enduro ring and pinion while carrying a larger bearing. Maybe one day. | |
07-13-2021, 05:50 PM | #48 | |
This is true. When I got home from work and checked the axles on my truck and the pinion is indeed quite centered as you've stated. BTA steering is cool, but indeed not a huge advantage. I have not experienced the pinion bearing issues, but I think that is because I put more mileage on my TRX-4 Sport kit with 2-speed. (Which I have chased all sorts of gremlins out of ) Also possible that I'm too forgiving of mediocre axles given there are two vehicles in my garage with Dana 30's. I'll keep being a fan of Element, even with the shortcomings. Your mileage may vary, but I'm happy to have kit out there that isn't part of the Horizon Hobby machine. My recent experience with a Mojave EXB has tainted my opinion of HH entirely. Last edited by CamoColton; 07-13-2021 at 06:00 PM. | |
07-13-2021, 06:18 PM | #49 | |
07-15-2021, 07:17 AM | #50 | |
I do have the Enduro axles in my sons C2 build with Brazin Chassis and TGH 2low. He is fine with them, to me the torque twist makes them "not dig in" when climbing. I do have more weight in the front wheels of them, 30% Over drive, I have adjusted the rear susp to help with he squat/anti squat and raised the rear pinion. All has helped but they just don't climb like my TRX portals or AR44s. There are certain terrain types were they are more lively or responsive, level but with obstacles. And that only happened after I went with servo on axle, new ends and steering link and and putting the steering link IN FRONT of the axle. That save a little time ( in that terrain) but their performance on steep climbs just isn't like the others. Last edited by MOguy; 07-15-2021 at 07:27 AM. | |
07-28-2021, 04:35 PM | #51 | |
Newbie Join Date: Feb 2021 Location: vt
07-29-2021, 06:36 AM | #52 | |
I also change my shocks to TRX ones. Last edited by MOguy; 07-29-2021 at 06:40 AM. | |
Element Enduro Builder's Kit... 2 - Similar Threads | ||||
Soze finally gets around to the Element Enduro Builder's Kit | soze | Element RC 1/10 Enduro Trail Truck Sendero | 34 | 11-05-2021 10:33 AM |
Dabbler does an Enduro builder's kit | johnnyluv | Element RC 1/10 Enduro Trail Truck Sendero | 3 | 04-03-2020 11:30 AM |
New Enduro Trail Truck Builder's Kit - In Stock! | RPP Hobby | RPP Hobby | 0 | 07-10-2019 11:27 AM |
Pre-Order Now - New Enduro Trail Truck Builder's Kit | RPP Hobby | RPP Hobby | 0 | 06-06-2019 07:06 PM |
