02-28-2007, 09:22 AM | #1 |
Rock Stacker Join Date: Oct 2006 Location: the hobby shop
| help with 3rd channel
has anyone set up a winch on channel 3 with a futaba 3pm radio.....how do i make a swith for it? any feedback would be greatly appreciated! oh, i did try the "holy" search button! |
02-28-2007, 09:31 AM | #2 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
Hi I have the 3pm-Fs radio and the slide buttom on the ''Right'' is the 3rd channel so you have to slide it across so it will turn the 3rd channel on. Hope this helps |
02-28-2007, 09:37 AM | #3 |
yeah, that i do know, but i must be doing somehting wrong...the 3rd channel always has power, in the "off" posistion, it goes one way, and in the on posistion it goes the other....
02-28-2007, 09:39 AM | #4 |
When you set the controller up you will have to set the controller up while the 3rd channel is OFF then set it up again with THE SAME setting's while the 3rd channel is ON
02-28-2007, 09:55 AM | #5 |
Pebble Pounder Join Date: Aug 2006 Location: Mobile AL
Just take you EPA's to 0% one way and the 3rd channel... Later, Jake |
02-28-2007, 10:13 AM | #6 |
and the 3rd channel............?
02-28-2007, 10:32 AM | #7 |
if i set the epa's to 0% on the 3rd channel, the minute i flip the swith they both go right back to 100%, and the servo always has power, but am i having problems because the servo no longer knows were center is....because i "modded" it for a winch?
