07-25-2021, 06:22 PM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Pin size on AR44 universal?
This is a longshot of all longshots. I recently picked up a set of used AR44 axles. For whatever reason the previous owner drove the stock pins out of the universals. The ones that go through the metal square and connect to the axle side of the housing.
08-10-2021, 06:05 AM | #2 |
| Re: Pin size on AR44 universal?
Part numbers in the manual https://www.google.com/url?sa=t&sour...wWANnjuCvDRAg6 Sent from my SM-N986U using Tapatalk |
08-11-2021, 01:28 PM | #3 |
| Re: Pin size on AR44 universal? those pins fall out all the time i use some solder on the ends to keep them in place infact my newest build lost its pin a few days ago lol i lost all the parts on the trail and had to order a new set i was still testing so i hadent soldered them up lol the new set will be soldered up before i install them
08-11-2021, 01:43 PM | #4 | ||
Pebble Pounder Join Date: Feb 2017 Location: Louisburg, NC
| Re: Pin size on AR44 universal? Quote:
Is it the pin in the middle of the attached image? | ||
08-12-2021, 06:11 AM | #5 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
| Re: Pin size on AR44 universal? Pin that holds the universal together is a 2x11 pin. You should be able to use a hex pin and get them back together.
08-12-2021, 06:31 AM | #6 |
| Re: Pin size on AR44 universal? im not sure a wheel hex pin is long enuff but you can cut down a drill bit and use that in a pinch some say there stronger than the original pin not that it matters much in this aplication
Pin size on AR44 universal? - Similar Threads | ||||
Driveshaft pin size... | Maxx_Action | G-Made Crawlers | 1 | 06-12-2021 10:02 AM |
Anyone run SSD AR44 HD locker/gears? Can't figure out hex size, coming from 1 piece. | jessedacri | General Crawlers | 10 | 06-01-2019 12:37 PM |
Broken VVD/Universal pin from over steering? | GTSLOW | General Crawlers | 25 | 10-08-2016 08:32 PM |
wildbore pin size. | sally1800 | Axial Wraith | 2 | 04-20-2014 04:54 PM |
Axial CVD stock pin size | RickM | Axial AX-10 Scorpion | 5 | 07-07-2011 01:15 PM |
