08-28-2021, 11:19 AM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| To much gear down a bad thing?
So we've all heard that famous phrase "volt up, gear down." My question is, is it possible to gear down to much and have heat issues? I.E., a popular gearing is 11/56 on Axial rigs. What if you ran 9/64? I suppose there's other factors but say we're talking about an otherwise stock SCX10II? Sent from my SM-N986U using Tapatalk |
08-28-2021, 12:12 PM | #2 |
| Re: To much gear down a bad thing?
Short answer in my experience, NO. Final drive ratio, is kind of the most important part... Spur/pinion, x axle ratio x transmission ratio. I am currently running 87:1 low gear ratio in my big Bronco, Ultimate Adventuring Bronco. Using a revolver and sw4. Low speed control is incredible and heat is never an issue... On the opposite spectrum my Trail King is running stock gearing (40:1ish)with a 16t Crawlmaster sport, and a fusion esc/Rx very good control and more heat. Wheelspeed is about the same, but the lower gearing is just incredible. |
08-28-2021, 12:24 PM | #3 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: To much gear down a bad thing? |
08-28-2021, 10:47 PM | #4 |
| Re: To much gear down a bad thing? 3.75:1 axle, 5.05:1 low gear in rc4wd AX2, 60/13 spur/pinion... 60/13=4.16 and change 4.16 x 5.05= 23.3 and change 23.3 x3.75 = 87.375 and change... The revolver startup is super slow, allowing you to actually count rotations aprox 60rpm maybe 100rpm. I love it despite the noise. The gear box is super noisy too so there is that as well. I will try to get a video in the next few days. |
08-29-2021, 04:26 AM | #5 |
I usually run 9/92 which is roughly 100:1 reduction. I have also had rigs that are 200:1. For the most part there are 2 downsides to gear reduction. 1 obviously reduced top speeds. 2 loud gear noise. My 100:1 rigs running 2200kv on 4s have excellent bottom end and are only walking speed running flat out. Going slow they aren't bad but at full throttle they sound almost like a revolver. Not a big deal as I drive pretty slow 99.99% of the time. This is 100:1 with a revolver if I remember correctly. https://youtu.be/0Ur5XGuuF64 I have a few older videos with a stock 35t motor at 126:1 and even they have plenty of torque. More then a torquemaster magnum at stock gearing for certain. https://youtu.be/0Ur5XGuuF64 Outrunner motors are the way to go IMO though. Sent from my SM-N986U using Tapatalk Last edited by Voodoobrew; 08-29-2021 at 04:44 AM. |
08-29-2021, 04:29 AM | #6 |
And I never had any heat issues running brushed. Sent from my SM-N986U using Tapatalk |
08-29-2021, 05:15 AM | #7 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Brushless motors can overheat quickly with no load, but I think just the gearbox and diffs in a crawler provide enough resistance.
08-29-2021, 06:34 AM | #8 |
08-29-2021, 06:40 AM | #9 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: To much gear down a bad thing? Quote:
9/92 is 10.222:1 at the pinion, I’m sure he is reference final drive ratio of 100:1 Assuming common/standard ratios: 10.222 x 2.6 x 3.75=99.66 2.6=axial 3 gear internal ratio 3.75 = ar44/ar45/vp/element standard ring and pinion ratio Sent from my iPhone using Tapatalk | |
08-29-2021, 01:37 PM | #10 | |
Bugs me when people only mention the pinion and spur reduction. Too many different drivetrains and custom options. Also depending on the method you choose for gear reduction you might introduce "slop" into the drivetrain. Sent from my SM-N986U using Tapatalk Last edited by Voodoobrew; 08-29-2021 at 01:40 PM. | |
08-29-2021, 07:56 PM | #11 |
Rock Stacker Join Date: Jun 2020 Location: Jakarta
I have one rig that geared low, and other than the gear noise, it runs cool. It uses 3 gears gearbox with 87/18 spur/pinion (still has plenty of room to bring it lower), scx10 III clone portal axles with OD portal gear (21/14). Total reduction is 70:1 at front axle and 90:1 at rear. This is the video of it running backwards against the door https://youtu.be/ZzHFpYdqz_Y Btw, it uses Holmes Crawlmaster Mini esc and Holmes Revolver 2040kv snubnose. Sent from my Redmi Note 8 Pro using Tapatalk |
08-29-2021, 08:02 PM | #12 |
Pebble Pounder Join Date: Feb 2013 Location: Fountain Hills Arizona
I'd think spinning the motor faster even with more voltage would keep it cooler unless the rig weighs a lot. Sure wouldn't be hard to test the theory out... Let us know. |
08-29-2021, 08:43 PM | #13 | |
I have a 1800kv v1 Revolver in a Bomber controlled by a Mamba X - so noisy, but still fun. I'll definitely be picking up the Holmes new silent Crawlmaster ESC soon, I have a another Revolver that needs to go in a rig (v2 this time - 2200kv). I would have commented on your vid, but you have them turned off, so I just gave it the ol' thumbs up! (I lived in Jakarta when I was a kid for a couple years - went to the JES school in the mid-'70s) | |
08-29-2021, 10:06 PM | #14 | |
I am not really familiar with the youtube settings, I upload it there just because I can not upload the video directly here Good to hear that you were in Jakarta in the '70s, I think you meant JIS (Jakarta International School) | |
08-29-2021, 11:37 PM | #15 | |
I even have a yearbook, somewhere! My mother is still friends with a family we spent a lot of time with back then, the parents have visited us in Texas. | |
To much gear down a bad thing? - Similar Threads | ||||
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
bad gear mesh...? | guapotaco | Axial AX-10 Scorpion | 2 | 02-17-2011 10:42 AM |
Too Much Traction a Bad Thing? | Harvo | Newbie General | 38 | 12-18-2008 10:12 PM |
TXT with gear Reduction. A good thing??? | Blitzer | Electronics | 12 | 02-19-2007 03:02 PM |
