09-15-2021, 06:54 PM | #21 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: High Clearance and Portals Quote:
09-15-2021, 07:46 PM | #22 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: High Clearance and Portals Very good observation! But I should have noted to ignore the driveshaft angles. In the first picture, I had the differential flipped so the portals would rotate the same direction as the front straight axle. I had to have the pinion/output flipped as well, so the driveshaft was low. I've since put in reverse cut gears to get the driveshaft flipped back up and out of the way. That's just the only picture I have of the whole vehicle from the side with the tires on and link bends at the axle.
High Clearance and Portals - Similar Threads | ||||
High offset, high clearance 2.2 wheels? | halllon | Tires and Wheels | 5 | 12-10-2020 05:02 PM |
I need BIG help choosing the highest clearance axles without going to portals. | Tim3 | General Crawlers | 22 | 11-10-2019 10:25 AM |
3racing high clearance knuckles(portals) - where to buy | Slowkrawl | Axial AX-10 Scorpion | 10 | 10-18-2012 10:21 PM |
high clearance chassis? | TNCrawler | Axial AX-10 Scorpion | 11 | 03-05-2010 08:36 PM |
