12-26-2021, 01:09 PM | #1 |
Newbie Join Date: Dec 2021 Location: Anniston
| Help with trans squeal/slip
Hi all, newb here. After a good run through the mud yesterday and a rinse off, I go to drive today and my drivetrain is squealing and slipping. I took the trans apart and inspected for missing teeth but all were accounted for. I noticed a little rust on the bearings so I drenched everything in PB blaster and then cleaned and reassembled the trans. I put a couple drops of synthetic motor oil on the gears as it's all I had. Thanks for help in advance! Video Redcat Gen7 Sport stock |
12-26-2021, 01:19 PM | #2 |
| Re: Help with trans squeal/slip
dose it make the same sound if you hold it upside down it looks like the problem is down the line and not the transmission it self try playing with the clutch some i would look at the drive shafts and make sure the axles spin free also check the motor it might have something stuck inside it like a screw or a rock or something ive had that happen more than once |
12-26-2021, 02:19 PM | #3 |
| Re: Help with trans squeal/slip |
12-26-2021, 02:44 PM | #4 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
When my SCX10 0G gets squeaky it's the universal U joint between the output shaft and the drive shaft (shown in your video too). Try putting a drop of lube in the pin(s) that keep the universal joint together.
12-26-2021, 06:05 PM | #6 | |
Rock Crawler Join Date: May 2021 Location: NorCal
| Re: Help with trans squeal/slip Quote: Since you're doing your tear downs for maintenance I would also start greasing stuff up for repelling water/debris. | |
12-26-2021, 08:17 PM | #7 |
its hard to tell but in the video when it squeals are you letting off the throttle or is it slowing down on its own if its slowing down on its own i would look closer at the motor maybe lube the bushings and look for crap in side the motor that bearing wouldent cause the motor to bog down dosent mean it isent bad though |
12-27-2021, 08:17 AM | #8 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
Sounds like a motor bushing to me. Easy check, too. Take off the pinion and roll it. If it's quiet, it's not the drivetrain. Then give the motor a little throttle and you'll know right away. If you clean out the motor (you can just run it slowly for a few seconds in a glass of clean water) and re-lube it and the noise persists, that cat done used up a big chunk of it's nine lives. |
12-29-2021, 01:44 PM | #9 | |
Side note, I responded to this right after I took the pinion off, but the moderator filtered my reply out. Oh well thanks y'all! | |
Help with trans squeal/slip - Similar Threads | ||||
Clutch slip? | audiobull | Traxxas TRX-4 | 7 | 08-10-2018 02:34 AM |
Non slip spur? | odyssey350kc | Axial Yeti | 2 | 08-08-2015 06:28 AM |
slip spray???? | eyeopenher | Paint and Body | 6 | 12-28-2010 09:36 PM |
Wreckluse Tire Squeal! | pigeonfarmboy | Videos! | 23 | 03-01-2009 06:42 PM |
Belt Slip | ehastings | General Crawlers | 17 | 04-19-2006 11:23 PM |
