07-16-2022, 09:22 PM | #1 |
Pebble Pounder Join Date: Jan 2020 Location: Northern Utah
| Driveshaft yoke preference
I'm looking for suggestions on center (from trans to diffs) driveshafts for my SCX10 frame build- now is there any advantage to traditional youk (like the c-configuration) or the ball socket type yoke. No budget guy here so the MIP type shafts are out- any ideas? The aggle is pretty steep in my mind but it's pretty much a stock set up with a 4 link set up- Thanks in advance
07-17-2022, 08:06 AM | #2 |
| Re: Driveshaft yoke preference
as a general rule the universal type are stronger the cv style is smoother but that goes out the window depending on what brand is making sead shafts the universal joint or u joint or whats being refered to as a c joint by the op works best when the trans output and axle pinion are parrallell the cv or constant volocity joint wants the axle pinion pointed at the trans output thats more real wold thinking on a rc it dosent matter so much 1 because crawlers dont go fast enuff to develop strange harmonics and vibrations and 2 the forces on the bearings and other componints are so small nothing is gona explode or ware out any faster cause yiur shafts are out of alignment and 3 your not in the vehicle basicly on a rc it dosent really matter what style shaft you use as long as its strong enuff to do what you need it to i like gds brand shafts but they just a rebrand of someone elses shafts and i dont know the parent companys name that actualy makes them and there cv style but they have been pretty strong incision makes some nice looking universal style shafts i have never used them my self but being a vanquish product im sure there bullet proof if your looking some something wild or just plain crazy the axial wildboar hd8 shafts are crazystrong for being plastic and there extremely easy to customize and the shaft kit is cheap the shaft ends arent cheap though but thats the beef part and once you have the ends you can make a shaft any size you need from 1 inch to 2 ft drive shafts you kinda get what you pay for its one part you dont want to cheap out on that sead mip might be over kill on most rigs you still need to be carefull though i look for hardend steel machined shafts with big beefy splines and stay away from anything stainless or aluminum if you do cheap.out there are some bandaids that can be done to keep the cheap shafts together sometimes but best to spend alittle extra for something you can trust especialy if your just getting started after rereading the original post i think the hd8 wild.boars might work best and since its axial already you know it fits heres a link to the full kit https://www.ebay.com/itm/13396045926...mis&media=COPY thats not cheap i know but you have other options like used https://www.ebay.com/itm/12426847175...mis&media=COPY and theres the spline kits if you want to make custom langths or twist a shaft https://www.ebay.com/itm/13388040375...mis&media=COPY and the coupler ends if you ever needed one https://www.ebay.com/itm/13291385092...mis&media=COPY Last edited by ferp420; 07-17-2022 at 08:19 AM. |
07-17-2022, 09:33 AM | #3 |
Them wild bores look promising- here is my problem is they don't look long enough now can I get the wild bores AND then a center spline kit? Now looking at the spline kit- seems theres only one side that has splines? I have a 4 link and the measurements are about 5 1/4 in to 5 1/2 " front and rear at full extension. I do appreciate the help I've been at this a long time but health issues (stroke) sometimes slows down my understanding of things -
07-17-2022, 10:29 AM | #4 | |
| Re: Driveshaft yoke preference Quote:
there are 2 differnt length a short kit and a long kit also i only linked the single spline kit there is a double spline kit too and they can be doubled up if you need a really long one then theres the yeti version center spline kit https://www.ebay.com/itm/39412804106...pid=1437965032 the used set was for a scx10.3 but would work on a 10.2 or a 10.1 they have have close to the same wheel base i dought you would need longer shafts but lots of options if ya do heck i have a wildboar shaft thats almost a foot long on a 1/8th scale hardbody raptor with the biggest motor that fit running 6s it will do atleast 50 mph and crawls rock drive shaft holds up fine i did reinforce th3 center splines with a metal rod they have a tendency to twist if they get to hot and at 50 mph things heat up kinda quick | |
07-17-2022, 11:16 AM | #5 |
nevermind the picture dident match the discription they werent the hd version there are wb8 shafts that came.on the scx10.1 you dont want.those you want the wb8-hd make sure its the wb8-hd version if you go that route Last edited by ferp420; 07-17-2022 at 11:25 AM. |
07-17-2022, 12:37 PM | #6 | |
Pebble Pounder Join Date: Feb 2022 Location: Batam Island, Indonesia
Quote and stay away from anything stainless or aluminum Unquote Why no aluminum? My YiKong comes standard with aluminum driveshaft... the kids just lost half of it so i ordered a new set that is aluminum also ... Trying to learn more in this new hobby € 12,94 26%OFF | 2Pcs Metal Drive Shaft For Yikong YK4082 Absima CR1.8 Yucatan 1/8 RC Crawler Car Upgrade Parts https://a.aliexpress.com/_mrrklQe Sent from my CPH1937 using Tapatalk | |
07-17-2022, 05:04 PM | #7 | |
07-18-2022, 03:41 AM | #8 |
| Re: Driveshaft yoke preference Ok got it, next time i will try different shafts if the kids loose them again Ps pinion & gearbox shaft diameter vs driveshaft hole diameter, The sellers only tell what RC it's for, not the hole diameter etc ... Is that common in the RC world ? Sent from my CPH1937 using Tapatalk |
07-18-2022, 07:25 AM | #9 |
almost all the 1/10 rigs these days have 5mm output/input shafts and most aftermarket parts are geared twards axial and there clones axial and traxxas have a differance in pin location on the input/output shaft and that can cause a issue but can still be worked around if ya need to the only time shaft size come in to play is with the minis and micros there not as standered as 1/10 scale |
07-18-2022, 12:45 PM | #10 | |
Do you guys make a "dent" hole in shafts so the grubs crew doesn't come out that easily? I could drill a 1 mm dent in my gearbox shaft & diff shaft ? and a bit of 222 locktite of course... Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 07-18-2022 at 12:48 PM. | |
07-18-2022, 02:39 PM | #11 | |
Driveshaft yoke preference - Similar Threads | ||||
Driveshaft preference | YDAZOPEN | General Crawlers | 9 | 03-13-2017 04:54 PM |
driveshaft/axle yoke problems | YJJPWrangler | Axial AX-10 Scorpion | 16 | 02-01-2011 08:05 PM |
AX-10 Metal Driveshaft Yoke | werewolf1983 | Newbie General | 2 | 02-10-2009 02:26 AM |
My driveshaft yoke keeps breaking loose. | jbrentd | Axial AX-10 Scorpion | 17 | 08-19-2008 06:37 PM |
driveshaft/yoke compatibility | TxCruzr | Newbie General | 5 | 03-09-2008 05:05 AM |
