01-26-2022, 06:07 AM | #21 | |
Newbie Join Date: Dec 2021 Location: Northfield
| Re: Rod End Hitting Motor Quote: I just was given a 3d printer so I've been messing with that a bit. Might see if I can print some tranny spacers and possibly make an angled one. Though I'm super new to 3d printing so we'll see what I can do lol. | |
01-26-2022, 06:46 AM | #22 | |
Yeah my motor isn't quite as long. My plan is to eventually swap in a brushless motor, so I'll see how works out then. Congrats on getting a 3D printer! Endless possibilities and a great tool to have! When I first got mine, it ran non-stop. | |
01-26-2022, 04:23 PM | #23 |
| Re: Rod End Hitting Motor Thanks! Yea I've been test printing stuff all day lol. I actually printed a 3 mm tranny spacer. But now I need to go get some longer tranny mounting screws. I got 4 Plano box's full of screws for rc but I don't have any of those weird counter sink self tapper screws that are used for mounting the tranny. So hopefully I can make a trip to Menards and find something that'll work. Wish I could just use some normal counter sink 3mm screws because I got plenty of those.
03-10-2022, 01:24 AM | #24 |
Newbie Join Date: Mar 2022 Location: Nevada
I noticed my rig was getting really twitchy when I was flexing up good, and that I'd get some sparks (very shortly) and I couldn't quite tell where they were coming from.. It ends up that on full flex, my links rest RIGHT ON my motor contacts techzpod.com mobdro apk Last edited by bariszop; 03-11-2022 at 05:39 AM. |
03-10-2022, 05:58 AM | #25 | |
Rock Stacker Join Date: Oct 2021 Location: Mansfield
Team garage hack has a shim that brings up just the low side of the transmission, it should solve the clearance issue and give you better angles on the drive shafts. https://www.teamgaragehack.com/colle...oducts/h-wedge Sent from my iPhone using Tapatalk | |
03-10-2022, 09:08 AM | #26 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
OR Maybe flip that link upside down? Or maybe a straight susp link. I have used high clearance links turned them sideways to clear motors. Last edited by MOguy; 03-10-2022 at 09:14 AM. | |
03-10-2022, 11:56 AM | #27 |
I'd use a single or maybe pair of washers under 1 side of the trans to raise the motor. It'll angle a bit and likely be enough. Rotate the links so they're flat, no reason to run a bent front link at all. |
03-10-2022, 04:13 PM | #28 | |
You can get away with using a standard M3 screw in place of the odd sheet metal/wood screws Axial uses. It will cut new threads but I havent had any issues switching to regular M3's. This is a great example of a super easy to design part you could 3D print Last edited by HumboldtEF; 03-10-2022 at 04:19 PM. | |
03-12-2022, 11:43 AM | #29 |
This is a great example of a super easy to design part you could 3D print[/QUOTE] I don’t have a 3d printer and not sure if or when I will get one. I am fabing up a cheater bed for my portal build though. Sent from my iPhone using Tapatalk |
Rod End Hitting Motor - Similar Threads | ||||
Tie rod hitting servo arm | meadus11 | Vaterra Ascender | 4 | 05-29-2020 07:31 AM |
rod end threads............ | bob1961 | Newbie General | 12 | 11-25-2008 06:01 PM |
Can you name this rod end?? | peej410 | General Crawlers | 5 | 04-09-2006 12:10 PM |
Rod End Help | onefstsnake | General Crawlers | 21 | 08-26-2005 11:15 AM |
