01-26-2022, 08:50 AM | #1 |
Pebble Pounder Join Date: Mar 2014 Location: brainerd
| chassis setup question atl pro v2
just ordered a atl pro v2 i think im going to put some capra axles under it and i ordered a tgh 2low ebr whats a light motor esc combo that you would go with will be trail runs / crawling also what length shocks would you go with to? also brand trying to order to many parts with nothing in hand yet and unshure what to do lol |
01-26-2022, 11:26 AM | #2 |
Quarry Creeper Join Date: May 2019 Location: Knoxville
| Re: chassis setup question atl pro v2
I've got GSpeed chassis with capra axles and the 2.low and I run snub nose revolver and a crawlmaster mini esc, or a sidewinder 4. I like a 2500kv motor since some of the obstacles I tackle require some wheel speed, but a 1400-1800 is what a lot of people run. As for shocks, you've got quite a few options. I've got everything from a Traxxas GTS to a Element Enduro to a Dravtech. Something in the 85-90mm neighborhood is a good place to start. |
01-26-2022, 12:14 PM | #3 | |
| Re: chassis setup question atl pro v2 Quote:
might try the proline prospec shocks 90mm i have others laying around i can try just wanted somthing decent to start with | |
01-26-2022, 02:04 PM | #4 |
Rock Crawler Join Date: Nov 2019 Location: Erie
Ben, given your application I would recommend the Castle Mamba Micro Crawler Edition. It’s 1/3 the size and I’ve run both escs in the same rig with the same 2 different Revolver motors and after tuning both escs for low speed control they’re equally smooth. Both will require a external bec unless running a direct power servo. The Mamba Micro Crawler Edition can be used sensored or sensorless which brings me to the next suggestion. I’d pair it with a Holmes Puller Pro Stubby V2 2200kv. You will be giving up a bit of low end versus a Revolver but Revolvers are not a great option for trailing either due to the design of the motor. Good luck with your choices and your project and we’re looking forward to updates.
01-26-2022, 02:27 PM | #5 | |
01-26-2022, 02:53 PM | #6 | |
01-26-2022, 05:53 PM | #7 | |
but yea usually have dirt/mud under the body after a trail run | |
chassis setup question atl pro v2 - Similar Threads | ||||
Locked Up RC Pro CMS setup question | Robudda | Axial SCX-10 | 2 | 08-30-2016 07:03 AM |
Dlux 2.2 Ultra Pro Chassis & limiting shocks question | Digital | EnRoute Berg | 3 | 11-30-2015 09:10 AM |
Flying with Scalers (ATL>NC>IL>CO>ATL) | SinCity | Chit Chat | 7 | 12-02-2012 10:57 AM |
RC4WD Pro-Scaler chassis question | fred0000 | General Scale Talk | 7 | 09-21-2010 06:43 PM |
