04-15-2022, 01:19 PM | #1 |
Quarry Creeper Join Date: Dec 2019 Location: California
| Axles for comp build? (Trx4 axles fit sherpa?)
I’m looking for axles for a THG Sherpa comp build, I have half a set of TRX4 axles, so that would be my preferred choice, but I’m worried about comparability issues with the Sherpa chassis. I also have a mix and match of ar44 parts, which is also an option, but I’d like to use portal axles. The trx4 axle may end up going on another build, so other axle suggestions are welcome. From what I’ve seen, ar44s are a popular option and has a really tight turning radius, but would the trx4 axles be much of a disadvantage? Thanks |
04-15-2022, 03:21 PM | #2 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Axles for comp build? (Trx4 axles fit sherpa?) Quote:
This build shows how I did it. Bob & Doug Mckenzie's King Richard Petty Truck Getting ready to build one for my new G-Shot truck. Ernie Last edited by CODYBOY; 04-15-2022 at 09:18 PM. | |
04-15-2022, 04:49 PM | #3 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
Hey, i still have that truck. I think ive put maybe 10 min run time on it. The only marks on it are a couple scuffs on the skid. It sits on the shelf lookin all purdy now Sent from my SM-A516V using Tapatalk |
04-15-2022, 08:50 PM | #4 |
It is one of my all-time favorite builds. Ernie |
06-28-2022, 08:21 PM | #5 |
Newbie Join Date: Aug 2019 Location: Springville
I like ar44’s And Capra axles
07-02-2022, 02:13 AM | #6 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
Why would anybody put trx4 axles in a "Comp" build ??
07-02-2022, 04:59 AM | #7 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Axles for comp build? (Trx4 axles fit sherpa?) |
07-05-2022, 06:39 AM | #8 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Axles for comp build? (Trx4 axles fit sherpa?) Advantages. Clearance, Strength, gear reduction, avaialbe, wider for stability, Disadvantages. steering and bigger portal, wider and harder to clear gates. I use them on my 4ws C3, probably not axles I would choose for a C2 or C3 build but people do. You can file the knuckles and get them to steer better. Last edited by MOguy; 07-05-2022 at 06:42 AM. |
07-12-2022, 08:50 AM | #9 |
Pebble Pounder Join Date: Oct 2018 Location: boise
07-13-2022, 08:18 AM | #10 |
07-13-2022, 08:57 AM | #11 |
Quarry Creeper Join Date: Mar 2021 Location: SOCAL
Indestructible!!! hummmm I have broken axle shafts with stock electronics on my TRX4 sport due to the limited angle. They are easy to find parts but the portal boxes and knuckles are bulky. I recently build a HH sherpa but i used the f10's off a Phoenix. they are such a great set of axles. If you are building a comp rig these axles got to be the best bang for your buck ... they are nice, smooth, portaled, high clearance pinion, weighted. quality. and not overly priced for what they are.
07-14-2022, 10:49 AM | #12 |
| Re: Axles for comp build? (Trx4 axles fit sherpa?) I agree here except for my C3. With some grinding, 4ws and the rear selectable locker it can almost turn in place. But nothing I would chooses for my C1 or C2. People do run them and unless the coarse is tight they do great.
07-15-2022, 11:36 AM | #13 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
I've built a 'comp' rig that I run in local comps. STH chassis and just the basics. It uses X4 axles and it's a regular top three finisher. I agree that steering is limited but for the majority (99%) of comps it isn't an issue. With some effort, the steering can be improved but the caster/pinion angle is problematic. (Traxxas should correct that.) I also have a 'full blown comp' rig. lol CCW chassis, custom this that and the other thing, and it has the F10 axles. I have to agree with Speedy Triple on the F10's. For the price they are absolutely amazing. They beat the X4 axles imo because they are around the same price, are easy to get, they can be bought individually, and they have the caster built in which makes the steering awesome. After several months of running them, torque twist is not an issue at all. |
07-29-2022, 05:28 PM | #14 |
Pebble Pounder Join Date: Feb 2022 Location: Batam Island, Indonesia
I saw these 1/8 axels and thought about this thread Heavy Duty YIKONG Brass Counterweights Portal Axle https://a.aliexpress.com/_mLoht78 86 Euro for a brass front axel, so you could make it all wheel steering? Sent from my CPH1937 using Tapatalk |
09-29-2022, 11:57 AM | #15 | |
My C2 has AR45 and turn great but already have a crack where the links mount. Maybe 3 comps and some practice/tuning. New case is only about $12. I did have a kink end break and I suppose that could have added to it. But in almost 3 years I have no breakable issues (other than a shafts because of increased steering and the chromoly shafts fixed that) with my TRX axles. My C1 has SSD diamonds (AR44) with SSD hubs. I have gone through the 1 piece ar44, twisted tubes on the SSD, a few axles and a set of hubs within 2 years. But they turn like an mm ffer. How heavy are the F10s compared to the AR45s? Last edited by MOguy; 09-29-2022 at 12:00 PM. | |
Axles for comp build? (Trx4 axles fit sherpa?) - Similar Threads | ||||
TRX4 sport axles with a comp chassis? | GSRswapandslow | General Crawlers | 3 | 02-17-2021 09:50 PM |
Will Trx4 c-hub and portal fit on Gen 8 axles? | Auntflowracing | Redcat Crawlers | 3 | 09-15-2019 07:52 AM |
Trx4 Axles with Axial Transmission. Advice for Class 2 Comp Build Please. | neilus | General Crawlers | 3 | 05-13-2019 09:13 AM |
do losi comp shocks fit bully axles | smedo | RC4WD Bully | 4 | 06-29-2009 09:05 AM |
