05-11-2022, 10:09 AM | #21 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Second crawler Quote:
05-11-2022, 11:29 AM | #22 |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: Second crawler
Actually if you have 4 link you have trailing arms. But for rc production, basically a rod with threaded ends for the ball sockets has been a standard so very easy to produce to any length. But the links we are used to in rc and the "trailing arms" of the ecto/GK do the same thing and are the same thing. Change comes from shock placement and the anti-roll bar, both attached to them instead of the axle. Shock placement does similar to what angling the shocks does (increases travel) of the axle, the sway bar would be to offset torque twist that crawlers with leaned over shocks are plagued with that spring and damper tuning can mostly fix. Now I haven't read up on why element designed it the way they did but being 1:1 background, that would be the basic breakdown of the point of the design. Sent from my SM-S906U using Tapatalk |
05-11-2022, 11:40 AM | #23 | |
Moving the shocks forward will change things but i suppose you can just use different shocks or tune them different. with a 1:1 you need to drive freeway speeds with a RC crawler you don't things are different. Last edited by MOguy; 05-11-2022 at 11:56 AM. | |
05-11-2022, 01:26 PM | #24 | |
05-11-2022, 02:13 PM | #25 | |
MOguy, quick info, can explain some suspension set up info in further details over pm if you like. I'm a couple hours north of you. Sent from my SM-S906U using Tapatalk | |
05-12-2022, 07:19 AM | #26 |
| Re: Second crawler
enuff with this he sead he sead poop this is all you need to know the hobby is addicting your gona buy them all just acept it and role with it till the intervention happens and they take your toys away you know your in trouble when your sitting on the end of a trail with a air compressor offering a blow job for a quarter to buy a new battery pack come on man your rig is dirty just let me blow it off man come on i need a new battery or when you pack up a weeks worth of camping gear to camp out at your local track and the track is behind a school in the middle of town less than a mile from your house or showing up to rc in riped torn dirty cloths and shoes with holes in them them pull out a $2000 rc car like i know my ass is hangin out but i cant aford a new pair of shorts cause i just bought new tires for my rc car Last edited by ferp420; 05-12-2022 at 07:31 AM. |
05-12-2022, 08:37 AM | #27 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
You’re right though, the idea of choosing this rig vs that is ridiculous. You’re going to buy them all sooner or later. | |
05-12-2022, 12:20 PM | #28 | |
Newbie Join Date: Jan 2022 Location: Middleboro
05-12-2022, 04:09 PM | #29 | |
Second crawler - Similar Threads | ||||
TCS - Novak Goat Crawler Systems in stock @ TCScrawlers.com - The Crawler Store | kevinlongisland | Vendors Market | 0 | 09-14-2007 09:34 AM |
