Wider heavy duty truck axles? Does anybody know of extra wide axles that resemble the ones on a heavy truck? (Big and preferably metal) I need something a little wider than the standard scx10ii or TRX4 axles. The track width with relatively small tires will be around 235mm, or 9 1/4 in. Locking diffs would be nice to have if possible, but I doubt there are many options. |
Re: Wider heavy duty truck axles? Quote:
There might be a knockoff/no name option out there to suit your needs, but (in my experience) the TRX and SSD parts are tested and proven. Unless you're okay with a "heavy duty" Baja style axle? And ~$200 per axle. Then you could try the RC4WD Rigid axles. They're ~9" pin to pin (iirc) approximately Axial AR60 width. Sent from my LM-V600 using Tapatalk |
Re: Wider heavy duty truck axles? SSD portal delete narrows the axles quite a bit. They work great, but maybe not the best for this application. Take a look at HPI Wheely/Crawler King axles. Can still find them around with some digging and patience. Or just pick up a roller and rob them off. They use Wraith/SX10V1 diffs so they can be built open diff, limited, or locked, and with OD and UD options. Easily modded for pass through if needed, and certainly chunky enough. They are 205mm at the hex faces, compared to 180mm for SCX10 axles. AR60's are always a good bet also - all of the above applies though maybe a bit too wide. They are 230mm at the hexes. You'd need wheels with a lot of positive offset. |
The HPI WK/CK would be an interesting choice. I didn't know they were compatible with the wraith diff. I kind of forgot they existed, too. That got me thinking about my CEN Racing HL150 though. I think those axles might be wide enough and have open diffs but I haven't looked into upgradability/tunability. Sent from my LM-V600 using Tapatalk |
Re: Wider heavy duty truck axles? I was thinking of SSD portal deletes on the TRX4 axle, I have one for the rear end of my trophy truck build that I'm working on. Pretty much bulletproof, only it is narrower than with the portals and I find that wheel hexes are hard to get perfectly straight. They don't have to be straight axles, just something that looks heavy duty. Maybe I can pick up a set of metal housings and diff cover with way too many lug nuts. I think some monster truck axles fit the look pretty well, only they might be too wide. |
Re: Wider heavy duty truck axles? theres the xrmod width axles you would need aftermarket parts and a ar44 housing to do the mod and capra axles are in the same size range but with portals ar60s are great axles if built right rift axles are just a hair wider than the ar60s then theres scx6 axles alot wider lol its easyer to extend your track width than it is to narrow your axles |
Re: Wider heavy duty truck axles? Too bad these are discontinued, they would have been perfect. I have a set and they have been fairly well beaten on with no issues. https://www.boomracingrc.com/boom-ra...ont-rear--3011 |
the front shafts are getting harder to find though not a big deal as wraith shafts cut down will work in a pinch to |
I guess its time to start digging |
i lied though there not built they just come with rear shafts the only issue with those is the wraith sized pumkin but you could mod a ar44 housing with beeftube parts to get that width and a smaller pumpkin it just costs more lol https://www.ebay.com/itm/31220414679...mis&media=COPY |
Re: Wider heavy duty truck axles? I found some of the XRmod axles on Ebay, are there any measurements on how wide they are hex to hex? |
Re: Wider heavy duty truck axles? At the hex faces (with Wraith style hexes) I measure 215mm. |
