10-29-2022, 02:38 PM | #1 |
Newbie Join Date: Aug 2009 Location: San Fernando Valley
| SCX10iii Servo Complications,,,,,,,big Sigh...
So,,,, My Holms Hobbies servo required a small bit of trimming to the Servo Mount crossbrace to fit correctly. Did That. Now my 25t Vanquish servo horn wont work, due to clearance issues. I've ordered a couple Servo horns that I THINK might work. I even ordered a Bumper/Crossbrace servo mount that MIGHT bypass the whole problem. I really didnt think replacing the steering servo was going to be such an issue I Should a Known What I SHOULDA done from the Beginning is ask the Forum SCX10iii owners, "What High Torque aftermarket servos are you guys running without fitment issues in YOUR Trucks?" |
10-29-2022, 03:44 PM | #2 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
| Re: SCX10iii Servo Complications,,,,,,,big Sigh...
I don't have am scx10III so no idea your issue but I've had to modify plenty of servo horns for clearance in other applications/ vehicles. No way you could do some grinding or trimming?
10-29-2022, 04:55 PM | #3 |
| Re: SCX10iii Servo Complications,,,,,,,big Sigh... Not with this Servo horn. The Stock Axial horn has a big, "OFFSET?",,,,allowing the working part of the horn to clear the frame. The Vanquish Horn (the one I got anyhow) Sits nearly flat on the body of the servo. The horn cant even be tightened all the way on the splines because it starts rubbing on the plastic Mount/Crossbrace. Also the horn can only move a few degrees to Driver side then it actually hits the Frame. The OFFSET on the Axial horn provides the clearance necessary for the horn to swing without hitting anything,,,,,until you approach full throw anyway. Here is a Pic. Stock Axial Horn on Left. Red Pointer pointing at the Offset. You can see there is a smaller offset on the other end too. Vanquish Horn on the right is pretty much flat. Last edited by Redharris; 10-29-2022 at 05:16 PM. Reason: labeling mistake |
10-29-2022, 05:09 PM | #4 |
RCC Addict Join Date: Mar 2019 Location: Hemet
I had to run the protek 10.3 specific servo horn on my gladiator I’m pretty sure Sent from my iPhone using Tapatalk |
10-29-2022, 05:47 PM | #5 | |
| Re: SCX10iii Servo Complications,,,,,,,big Sigh... Quote:
https://www.amainhobbies.com/ruddog-...p-0088/p538046 | |
10-29-2022, 09:28 PM | #6 |
I said protek but I guess I meant Samix. This is the one I’m running https://www.amainhobbies.com/samix-s...22f-b/p1234694 Sent from my iPhone using Tapatalk |
11-12-2022, 05:04 PM | #7 |
This is what ended up working for me. Here is a link..... https://www.amainhobbies.com/ruddog-...p-0087/p538045 Here are a couple Pics,,,,Cuz we all like pics |
SCX10iii Servo Complications,,,,,,,big Sigh... - Similar Threads | ||||
complications on step 2 with my SCX10. I NEED HELP!!! | yotalove89 | Newbie General | 13 | 03-23-2011 04:09 AM |
Another EXPENSIVE hobby... sigh!!! | DumbDawg | Newbie General | 4 | 03-09-2009 04:43 PM |
Sigh, already broke it. | kikcaffine | Losi Mini-Rock Crawler | 5 | 09-25-2008 11:26 AM |
(sigh) cant seem to win...trip is OVER.. | 1BadJeepBruiser | Chit Chat | 46 | 05-29-2007 04:50 AM |
sigh | ILoveRCRockCrawlin | Chit Chat | 14 | 08-14-2005 12:47 AM |
