ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? 𝙸 𝚊𝚖 𝚕𝚘𝚘𝚔𝚒𝚗𝚐 𝚏𝚘𝚛 𝚒𝚍𝚎𝚊𝚜 𝚝𝚘 𝚖𝚘𝚞𝚗𝚝 𝚖𝚢 𝚗𝚎𝚠 𝚌𝚘𝚙𝚙𝚎𝚛𝚑𝚎𝚊𝚍 𝟷𝟶 𝙴𝚂𝙲 𝚝𝚘 𝚖𝚢 𝚃𝚁𝚇-𝟺 𝚂𝚙𝚘𝚛𝚝. 𝙵𝚛𝚘𝚖 𝚠𝚑𝚊𝚝 𝚒 𝚌𝚊𝚗 𝚜𝚎𝚎 𝚝𝚑𝚎𝚛𝚎 𝚒𝚜 𝚗𝚘 𝚠𝚑𝚎𝚛𝚠 𝚝𝚘 𝚙𝚞𝚝 𝚜𝚌𝚛𝚎𝚠𝚜. 𝙸 𝚊𝚖 𝚠𝚘𝚗𝚍𝚎𝚛𝚒𝚗𝚐 𝚒𝚏 𝚊𝚗𝚢𝚋𝚘𝚍𝚢 𝚔𝚗𝚘𝚠𝚜 𝚘𝚏 𝚊𝚗𝚢 𝚖𝚘𝚞𝚗𝚝𝚜 𝚘𝚛 𝚖𝚊𝚢𝚟𝚎 𝚐𝚘𝚘𝚍 𝚒𝚍𝚎𝚊𝚜 𝚘𝚏 𝚑𝚘𝚠 𝚝𝚘 𝚖𝚘𝚞𝚗𝚝 𝚒𝚝 𝚝𝚘 𝚖𝚢 𝚝𝚛𝚞𝚌𝚔. 𝙼𝚢 𝚘𝚗𝚎 𝚒𝚍𝚎𝚊 𝚒𝚜 𝚝𝚘 𝚞𝚜𝚎 𝚍𝚞𝚊𝚕 𝚕𝚘𝚌𝚔, 𝙸𝚝 𝚑𝚘𝚕𝚍𝚜 𝚟𝚎𝚛𝚢 𝚠𝚎𝚕𝚕. 𝙸𝚝 𝚊𝚌𝚝𝚞𝚊𝚕𝚕𝚢 𝚑𝚘𝚕𝚍𝚜 𝚖𝚞𝚌𝚑 𝚋𝚎𝚝𝚝𝚎𝚛 𝚝𝚑𝚎𝚗 𝚟𝚎𝚕𝚌𝚛𝚘. 𝙱𝚞𝚝 𝚒 𝚊𝚖 𝚑𝚘𝚙𝚒𝚗𝚐 𝚝𝚘 𝚏𝚒𝚗𝚍 𝚊 𝚖𝚘𝚛𝚎 𝚙𝚎𝚛𝚖𝚊𝚗𝚎𝚗𝚝 𝚖𝚎𝚊𝚗𝚜. 𝙼𝚊𝚢𝚋𝚎 𝚊 𝟹𝙳 𝚙𝚛𝚒𝚗𝚝𝚎𝚍 𝚑𝚘𝚕𝚍𝚎𝚛 𝚝𝚑𝚊𝚝 𝚠𝚒𝚕𝚕 𝚜𝚌𝚛𝚎𝚠 𝚜𝚘𝚖𝚎𝚠𝚑𝚎𝚛𝚎. 𝙸𝚝 𝚌𝚘𝚞𝚕𝚍 𝚐𝚘 𝚘𝚟𝚎𝚛 𝚝𝚑𝚎 𝚝𝚘𝚙 𝚘𝚏 𝚝𝚑𝚎 𝙴𝚂𝙲 𝚊𝚗𝚍 𝚜𝚌𝚛𝚎𝚠 𝚒𝚗𝚝𝚘 𝚝𝚑𝚎 𝚘𝚛𝚒𝚐𝚒𝚗𝚊𝚕 𝚜𝚙𝚘𝚝𝚜 𝚘𝚛 𝚜𝚘𝚖𝚎𝚝𝚑𝚒𝚗𝚐. 𝙰𝚗𝚢 𝚊𝚗𝚍 𝚊𝚕𝚕 𝚑𝚎𝚕𝚙 𝚒𝚜 𝚐𝚛𝚎𝚊𝚝𝚕𝚢 𝚊𝚙𝚙𝚛𝚎𝚌𝚒𝚊𝚝𝚎𝚍. |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? Servo tape, 3m double sided tape, that dual lock velcro, all hold really good. I use 3m double sided tape. My truck has takin some looooooong falls n never had a problem with esc comin loose |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? I use 3M double sides tape on all my ESC mounts. Have for 30 years, never have a problem. |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? 3M double sided tape. I was very skeptical about using that at first but after seeing the beatings that some of my rigs have took and never having it come loose I have no more worries about it. Plus you can still remove it really nicely if you take your time. |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? e6000!! |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? Thank you all very much. I might have to go with the double sided tape for now. I am hoping to get someone to 3D print a mount for the ESC for me at some point. |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? Quote:
The mount bolts into the stock ESC holes, and has a built-in bracket for the ON/OFF switch, as well as a bracket for tidying up the cabling. But, in the end, the ESC is still attached with double-sided servo tape. I did experiment with so bracketry to have the mount hold the ESC in, but in the end the whole mess became overly cumbersome. Recommend 3-M servo tape (the thicker stuff), it just works. And, clean the ESC and the mounting location with isopropyl alcohol before the tape is applied. http://www.rccrawler.com/forum/traxx...s-trx-6-a.html |
Re: ℂ𝕠𝕡𝕡𝕖𝕣𝕙𝕖𝕒𝕕 𝟙𝟘 𝕞𝕠𝕦𝕟𝕥𝕚𝕟𝕘? Thank you all very much. |
