| | #1 |
| RCC Addict ![]() Join Date: Jan 2004 Location: Louisville Kentucky
| It's nothing special but I thought some of you guys might get a kick out of it Mag mayhem running the lowest gear ratio I could find T-maxx suspinsion links TLT-1 axles, locked and ball raced (four wheel stearing). HS-625MG front servo Suicidal standerd servo out back (no saver Modded TQ3 radio system for 4ws Pede tranny will all metal gears (locked) and no slipper Pede sliders with steel outdrives Stock shocks Soon-to-be narrowed pede rims painted with "faky" beadlocks Swamp dawg tires HPI Bronco shell ![]() All that's left is the chassie and I'll be crawling |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: May 2004 Location: portland OR
| oooooooo, you stole the idea right out of my head!!!!!!!! jordan |
| | #3 |
| That Was Totally Ninja! ![]() Join Date: Mar 2004 Location: Whore Island
| Awesome! It should look kinda like mine when it's done, in that I designed mine to fit Tmaxx bodies and it uses 2.2" swamp dawgs. (Awesome tires) Cant wait to see it done! here are some pics of mine: http://www.gerrish.net/rc.htm -ryan |
| | #4 |
| RCC Addict Join Date: Apr 2004 Location: Santa Clara
| Nice Ryan. What is cool is my suspension looks identical to what you have done. I was skeptical at first that it was all strong enough, but the plastic seems to hold up pretty good so far to the twists tugs and pulls. I will have to snap up pics. Very cool. I can't wait to see yours out the door. Mine will have .... ummm... not sure yet actually. Just shooting from the hip as I go. I know this though. Once I pick a motor, it will have low geared transmission and a custom T-case. I have it on paper and parts on order. Just can't wait to see it all come together. Just need to find good driveshafts. So the Swamp Dawgs hook up pretty good eh? -Sam EDIT: So I found the camera and snapped up my first shot of the little guy. The wheel base is a bit too long and the temporary chassis isn't the right shape. Other than that, I am on my way to my first crawler. |
| | #5 |
| Hi Sam, Looks good! Yeah the swamp dawgs are nice- a little taller than the Geolandars, and they have deep void (especially with a few lugs removed) for mud-slinging action. Hey, I just realized that you are the same Sam that I went wheeling with in Hollister! (I've got the Haflinger) Good to see you in RC! later, Ryan |
| | #6 |
| Rock Stacker Join Date: Feb 2004 Location: Sweden!
| Damn you!!!! Now I have to get a TLT-1!!! That is soooooooooo cool... |
| | #7 |
| Quarry Creeper Join Date: Jan 2004 Location: NEW YORK!!!! long island
| what type of hex's do those wheels use or is it like a roll pin ??? |
| | #8 |
| The Hex's appear to be a standard size if one exists. I say this because I took the wheels off of an HPI gas 4wheel drive truck and they nearly bolted on perfectly. They use a solid pin through the axle to connect to the hex. The main problem with the rims from the HPI truck is that they require a slightly longer axle shaft to get more thread engagement on the nut. Not too bad though as it sits. I will probably make or find some heavier rims though to put some weight down low. -Sam |
| | #9 |
| Thanks alot guys! Kinda suprised me that there would be any intrest in such a project Jordantor, sorry bud! I think Ryan got to it first (he had a blue Land cruiser bod on the first incarnation of his now 8x Rbgerrish, thanks alot man, I got alot of insperation from your blue Land Cruiser and the new Chevy. You build some killer stuff! 8O Slinkysam, it looks like you have a very nice bass there. At first I was not planing on using the servo mounts as link mounts but after looking at the geometery it looks like it would be a wise idea to keep them where they are and triangulate the bottem links. I think I'll add another set of aluminum servo mounts behind the others for streangth though. DCLXVI, why don't you own one in the first place? In relation the the hex thing, I'm using stampede "fronts" all around and they dont fit A small update I haven't made a huge amount of progress in terms of actualy building anything but I have finnalized my chassie design and the all important paint job. The wheels are narrowed and I built the beadlock rings from lexan, I also modified them so that the lock nut could be fully screwed down. The plastic for the chassie is on it's way so I'm hoping to have it going under it's own power by monday |
| | #10 |
| Rock Stacker Join Date: May 2004 Location: Woodland Hills, CA & Anasco, PR
| That is awesome, good job so far Highmark, keep us updated. The TLT its an awesome little truck with great potential, here's some pictures of my TLT project i'm working on right now. Still need to install the pede tranny and build a custom chassis but with this setup the stock one works great, for now. Does anybody know the wheelbase measurement of the hpi bronco and the jeep body? It would be of great help! ...and the pics... |
| | #11 |
| The wheelbase of my TLT right around 12", and it fits Tmaxx bodies pretty well... Great pics by the way! ryan |
| | #12 |
| Thanks alot SROlmeda, mine is about 11 1/2" I believe. Your truck looks great btw |
| | #13 |
| Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
| My notes have the Bronco body at 11" wheel base. |
| | #14 |
| now what wheels are those im sorry i kinda asked it already but ihave mine and im going to bu new rims and tires just dont know what i should get i like the ones aboce the chromw deep dish rims what are those like IMEX or something im soryr if i sound like im repeating my self |
| | #15 |
| also what type of drive shaft is that is it the stock one because im making a chassis for mine and i figured if i extend the wheel base im gunna need a new one is taht custom?? |
| | #16 |
| Thanks for the compliments guys The rims are Duratrax Overdrive ST rims firstumustcrawl, theyre about $8 a pair on TowerHobbies. The driveshafts are from an HPI rs4 MT, but imo, the only way to go here its with traxxas half shafts. What about the HPI Jeep Wrangler Rubicon wheelbase? Does anybody have that number? :? |
| | #17 |
| It would be my guess that it's the same, if not really close. |
| | #18 |
| Rock Crawler ![]() Join Date: Apr 2004 Location: here
| this looks like good project for my kid, but what i wanna know is can we use the stock TLT tranny & chassis for his first project i think i just wanna keep it simple and straight forward so he won't have to break the bank in parts. body, maxx links, dogbones & body what do ya guys think? |
| | #19 |
| I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Nishru, are you by any chance a member of RCMT? I know its bad to advertise other boards... however, I have a 6 page thread on converting to a 1:10 TLT. It has alot of info on it. including how to make a stock TLT 1:10 using different traxxas parts, its actually pretty darn simple, and requires little fabrication. If you cannot get into RCMT, let me know, and I can create a new thread in the small scale crawler forum, with all the part numbers and info to get started. The TLT-10 conversion will cost you about $250-270 for the TLT kit itself and the extra parts, tires, and body. Electronics will be added on top of that. Oh, I forgot you wanted to keep dog bones, so it'll cost a little less. THe traxxas ball diff to adapt to sliders will run about $35 (w/sliders), so you can take that off the top. SRO, most maxx bodies have a wheel base of about 270-280mm, so its probably in that range. |
| | #20 |
| Thanks for the info PwT. You can also use the stock TLT diff and axle yokes with the traxxas sliders, just crank up the dremel and start cutting, thats what i did with mine and it works great |
| Thread Tools | |
| Display Modes | |
