03-05-2005, 04:23 PM | #1 |
| stripped screw
well i managed to strip screw head on my on servo that hold the servo horn... any idea ? |
03-05-2005, 04:29 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Try slotting the head of screw with a dremel cutoff wheel, for a flathead screw driver. You'll probably have to sacrifice the horn.
03-05-2005, 05:01 PM | #3 | |
03-05-2005, 05:06 PM | #4 |
What kind of head is it, phillips, allen?
03-05-2005, 05:27 PM | #5 | |
03-05-2005, 05:54 PM | #6 |
Pebble Pounder Join Date: Oct 2004 Location: san francisco
i dont know if this will work but put the screw driver on the screw and full the stripped area with solder or solder something to the screw and twist it out |
03-05-2005, 06:01 PM | #7 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
03-05-2005, 06:13 PM | #8 |
Pebble Pounder Join Date: Jan 2005 Location: st marys
Or you could have gone to sears They have a set of srew extractors for about 30 dollars I thinck. Basically you put it in a drill and spin it slowley in reverse while putting allot of pressure on the srew. It does a good job. |
03-06-2005, 03:19 PM | #9 | |
Rock Stacker Join Date: Aug 2004 Location: wasatch front
03-06-2005, 04:38 PM | #10 | |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
03-06-2005, 04:42 PM | #11 |
Rock Crawler Join Date: Mar 2004 Location: Albany
You could of used alittle 5 minute JB weld on the end of the screw driver and held it to the screw head till it dried then removed it also.
