Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Has anyone done a dual triangulated 4 link?
Old 06-08-2004, 10:30 PM   #1
Default Has anyone done a dual triangulated 4 link?
For my next project, which will be a tube chassis, I am thinking about doing a dual triangulated 4 link. Has anyone done this? Here's what I'm talking about
AdamF is offline   Reply With Quote
Old 06-08-2004, 10:46 PM   #2
31st place in 2006 Nats!!
toyofast's Avatar
Default Re: Has anyone done a dual triangulated 4 link?
I'm debating wether or not to do it once I get a new chassis and new links.... but I have yet to see many RC Crawlers going that route. Just seems like triangulating the upper links tends to be the norm.
toyofast is offline   Reply With Quote
Old 06-08-2004, 11:08 PM   #3
Well, in real life it reduces rear steer, if done properly. provides a LOT of strength in keeping the axles centered...
But keep in mind, these aren't real trucks! I'd be surprised if it was worth the effort. And it'd be tough to do on a clod.
SR5Dave is offline   Reply With Quote
Old 06-08-2004, 11:10 PM   #4
I'm trying it on my TXT... It's almost ready to run
Joe
kona_joe is offline   Reply With Quote
Old 06-08-2004, 11:46 PM   #5
PapaGriz Yo
Grizzly4x4's Avatar
Good thinkin Adam, nuthin wrong with tryin new stuff, especially if it werks on 1:1 rigs.
Like my coil spring suspension, sometimes you notice stuff that makes you think it makes a difference but it's hard to say for sure.
Kona, yer truck looks sweeeet!
Grizzly4x4 is offline   Reply With Quote
Old 06-08-2004, 11:55 PM   #6
Why would it be hard? Just use the regular 4 link top post mount on the axle, and fab up a simmilar mount on some sort of crossmember on the chassis.
Old 06-09-2004, 12:13 AM   #7
My thoughts exactly. A TXT would be nice and easy to do the dual triganulated 4 link on. I am doing it to mine, whenever I get off my lazy 2nd shift working butt and do it.
bustedcrawler is offline   Reply With Quote
Old 06-09-2004, 02:46 AM   #8
I did it on my buggy and it worked out good, eliminated all axle steer, which may not be a concern for some but I didn`t want any. And it does a great job of locateing the axles securely. There isn`t a great amount of triangulation on the uppers ( looks almost nonexistent due to the bends to clear the chassis on up travel) but seems to do fine. I was tring to keep the lower part of the chassis as narrow as possible.
4XADICT is offline   Reply With Quote
Old 06-09-2004, 05:20 AM   #9
Colt Python/SR9c
TwistedCreations's Avatar
i did it on the Widow also. i went that route right off the bat since it has done so well on the 1:1 rigs
TwistedCreations is offline   Reply With Quote
Old 06-09-2004, 11:48 AM   #10
The lowers would most likely hit the engines when you tried to bring them in. The uppers are easy, that is how mine are mounted.
Old 06-09-2004, 12:10 PM   #11
I haven't personally but a buddy in my 1:1 4x4 club did it on his Jeep. It works really well. If you understand the phyisic behind them it's a great way to go. You'll need to find out you COG, the antisquat percentage you are looking for, and you damn drawing a blank. Doing a 4 link the right way will give a dual tri set up. I"m sure the Pirate4x4 board can answer all your questions just search before asking. Check the tech section too."The answers are out there will help you find them." PBB(actually it's OSH ad)
rckjeep is offline   Reply With Quote
Old 06-09-2004, 05:27 PM   #12
One thing about AS, your COG and link geometry... They're not real trucks. It only sort of applies. In the real world my truck would perform horribly.. but it does ok since its not a real one!
Old 06-09-2004, 05:31 PM   #13
Colt Python/SR9c
yeah i didn't find my COG and all that crap on mine and it works like a dream. now if i was doing it to my 1:1 rig, then i would go through all the trouble of that stuff, but not on my RC
Old 06-09-2004, 06:55 PM   #14
So do the links sit parallel to each other, or is one at an angle or what?
I could always bend the links to wrap around the motors.
Old 06-09-2004, 08:32 PM   #15
They’re pretty close... Try to keep your upper & lower mounting points the same distance apart for the axles and frame.
Joe
Old 06-10-2004, 09:35 AM   #16
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
I've always run a mildly double-triangulated setup on my Clods......
Joe
Why?
Jay
roktoy is offline   Reply With Quote
Old 06-10-2004, 12:07 PM   #17
I was only suggesting that if he wants the links to be parallel to each other, he should keep the mounting points similarly spaced.
Joe
Old 06-14-2004, 10:12 PM   #18
what does links being parallel do? help with crawling, cog, up and down travel, what? thats a big question i have been wondering
bajabeast is offline   Reply With Quote
