Thread: How heavy is too heavy?
Old 05-16-2007, 12:43 PM   #1
Default How heavy is too heavy?
My 1:6 rubiclod rig is starting to gain weight. It's weighing in at 8.5 lbs.
Should i put it on Jenny Craig or will it be ok as a heavyweight?
Clod axles
integy 55t
9t or 10t pinions
evx esc single battery mod/optional dual battery
nylint tires/wheels
muddeprived is offline   Reply With Quote
Old 05-16-2007, 12:47 PM   #2
that really doesnt seem too bad for a 1/6.
xjwalt666 is offline   Reply With Quote
Old 05-16-2007, 09:11 PM   #3
My 2.2 weighs that or More....
Old 05-16-2007, 09:14 PM   #4
I guess i'll be alright then. Still got some shi$ to add and probably end up around 75 lbs
Old 05-16-2007, 09:16 PM   #5
Keep it real
Tanis's Avatar
My buddies comp maxx super truck weighed in at just under 12lbs , yes it was a pig
Tanis is offline   Reply With Quote
Old 05-17-2007, 04:41 AM   #6
that aint bad my 2.2 weights about that
Mikekx65 is offline   Reply With Quote
Old 05-17-2007, 05:04 PM   #7
8.5 lbs is heavy? Hmmmm. I was guessing my Clod was going to weight 20 lbs...I dont own any crawlers yet so maybe im being conservative in my weight estimate. I was going to stick two Z3025-12 on it though...
DKNguyen is offline   Reply With Quote
Old 05-17-2007, 05:07 PM   #8
9.3 now.....just added beefier links, alum tonneu cover, and a full size spare. I haven't mounted the electronics yet. I'll probably hover around 11 when i'm done.
Old 05-17-2007, 05:31 PM   #9
TLTCrawlin's Avatar
I had a TXT for a few days, 1/6er full tuber at like 15 lbs. Nylint body, full tube chassis, bumpers, TXT axles, txt trans with a nitro rusty t case.
A pig, and it only weigheed 15lb roller!
TLTCrawlin is offline   Reply With Quote
Old 05-17-2007, 05:45 PM   #10
Built, not bought
62PYRO's Avatar
My Clod super weighs that.Then again,It's mostly aluminum.
62PYRO is offline   Reply With Quote
