Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Driveshaft slip joint travel?
Old 06-12-2004, 12:49 AM   #1
TEAM MODERATOR
Reflection's Avatar
Default Driveshaft slip joint travel?
On a crawler with alot of wheel travel,how much slip would a guy need? I've given alot of thought about just using maxx sliders and may end up using them at first. I'd kinda like to try and build some custom shafts though. I'm just guessing here but would 1" of slip be enough? Or would that be to much
Just curious what others are doing for slip joints in their shafts and how long they are.
Thanks
Reflection is offline   Reply With Quote
Old 06-12-2004, 01:57 AM   #2
31st place in 2006 Nats!!
toyofast's Avatar
Default Re: Driveshaft slip joint travel?
I think 1" of slip would be plenty on most crawlers. On Tater-Tot which is now at 16.5" WB my Maxx sliders only use up about 1/2" of slip at most. My drivelines are nearly flat and my droop is limited to help keep the beast under control and from over flexing...even though I can get it almost to a full 90* of articulation now
So, yeah... 1" should be plenty.
toyofast is offline   Reply With Quote
Old 06-12-2004, 07:36 AM   #3
Colt Python/SR9c
TwistedCreations's Avatar
my Widow only uses about 1/4" of the slip on my maxx sliders for my driveshafts.
TwistedCreations is offline   Reply With Quote
Old 06-12-2004, 02:13 PM   #4
I thought it was "go big or go home"???
AdamF is offline   Reply With Quote
Old 06-12-2004, 03:53 PM   #5
Colt Python/SR9c
yeah but i can get 11.5" under one tire while the rest are planted. so i say thats pretty big the only time your shaft will use the slip is when the whole axle moves up and down and not when it just twists ( flexing)..i can twist the axle up and down( 1 up and one down) as if it were flexing out both sides and the DS doesn't slide hardly at all..it only moves when the axle goes up and down
Old 06-12-2004, 04:13 PM   #6
toyofast's Avatar
I can get 13.5" before a tire lifts.... and I run Kongs Although it's useless with that much on my rig, it's at 90* of articulation and that's only going to cause me problems on the rocks.
Old 06-12-2004, 05:09 PM   #7
TEAM MODERATOR
Reflection's Avatar
the only time your shaft will use the slip is when the whole axle moves up and down. It only moves when the axle goes up and down
Are you saying that when the axles moves straight up and down(not flexing it) it only uses 1/4"? Or is that during flex and it uses a little more when you,say, jump it or anything to get the axle to fall straight down?
Thanks everybody
Old 06-12-2004, 05:16 PM   #8
Colt Python/SR9c
like when i jump or if it starts to wheel hop.. the only time mine will move is during that time when the axle moves up and down..
now during flex, you ould hold the chassis in one hand and twist up the rear ( or front) axle to simulate flex, and the shaft will not slide in or out..it may just a **** hair, but thats only due to the axle dropping some during that time...i'll BRB with a couple pics if i can( battery is almost dead in camera) if not, i will post some up later for ya
Jeremy
Old 06-12-2004, 05:18 PM   #9
Colt Python/SR9c
TOYO- has anyone called you a smartass today yeah i can go more, but like ya said, it only causes problems and i really don't see a need for that much articulation ya ramp queen
Old 06-12-2004, 07:44 PM   #10
Colt Python/SR9c
steve, i just went out and took 3 pics..fully compressed,fully extended, and twisted up.. i tried to upload them so i could post them up, but i guess Roadrunner is having problems and i can't upload them to my little webspace
if ya want, i can send them to ya..if ya do, send me an email..mine is Toyotafourwheeln@cinci.rr.com
Jeremy
Old 06-12-2004, 08:15 PM   #11
TEAM MODERATOR
Reflection's Avatar
Mail sent,Thanks buddy
Old 06-12-2004, 08:31 PM   #12
Whats slip?
BushWacker is offline   Reply With Quote
Old 06-12-2004, 08:54 PM   #13
Colt Python/SR9c
Steve, back at ya.. no problem
Originally Posted by BushWacker
Whats slip?
are you serious?? ok actually maybe you are..just messin with ya. . when we are talking about slip for the driveshaft, its the amount the driveshaft travels in and out of each other..you have 2 basic parts that make up a maxx slider driveshaft- a female and a male..the slip is how much the male slides in and out of her( i mean the female end )
Old 06-12-2004, 08:55 PM   #14
TEAM MODERATOR
Reflection's Avatar
Whats slip?
The slip joint in the driveshaft is the one joint thats kept slippery with grease so it'll slide on the rocks better.
Old 06-12-2004, 09:03 PM   #15
Colt Python/SR9c
ROTFFLMFAO
maybe that's why i get stuck on rocks in my 1:1 crawler, i keep forgetting to grease that damn thing
Old 06-12-2004, 09:05 PM   #16
TEAM MODERATOR
Reflection's Avatar
Got the pics. Thanks a bunch. Looks like I'll need less slip joint grease than I was thinking.
Old 06-12-2004, 09:48 PM   #17
Colt Python/SR9c
no problem...yeah like i said in the email, if ya look close, you can see the wear marks on them. it maybe only moves a 1/4" for all the travel i have. if you ever have a problem with them twisting, you could always lengthen them and just leave 1/4" or however much yours move. that way it doesn't really show enough splin to twist
