Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: miniature u-joint adapters
Old 06-14-2004, 05:00 PM   #1
Default miniature u-joint adapters
I'm new here. Actually, I just registered but have been lurking for a little bit.
I have a Kyosho Mini-Z Overland that I'm looking at customizing into a 4WD crawler. I have a mod posted by someone else which turns the 2WD stock vehicle into a true 4WD, but it involves turning the entire front axle. I designed a system that would allow using steering knuckles to turn just the wheels, but need help in machining the u-joint adapters for it.
Is there anyone here that can help me out if I provide the design and dimensions?
Thanks!
Stoovey2004 is offline   Reply With Quote
Old 06-14-2004, 07:12 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Default Re: miniature u-joint adapters
you may wanna talk to ACE. he seems to be the machine specialist.. also, skpstr is a machine operator ( CNC) both are on the board so you may want to get ahold of them and see what the say.. there are a TON of mechanical engineers on this board
TwistedCreations is offline   Reply With Quote
Old 06-14-2004, 08:47 PM   #3
TEAM MODERATOR
Reflection's Avatar
And 1 dumb brick layer
Sounds like a neat project. Post up some pics so we can see.
Reflection is offline   Reply With Quote
Old 06-14-2004, 10:08 PM   #4
Ace
Post a pic of what ya need with some dimensions
Ace is offline   Reply With Quote
Old 06-14-2004, 10:36 PM   #5
Okay, I'll do that as soon as I finalize the design. I'm just a C++ programmer, but I have had some mechanical design education in the past...
I should have the design ready later this week or by the middle of next week. Thanks in advance!
