06-29-2007, 05:25 AM | #1 |
Pebble Pounder Join Date: Jun 2007 Location: Juneau, AK
| What battery will fit in the stock GRC
What battery will fit in the stock GRC? I have heard that it requires a special battery, and that the standard 6 cell stick packs do not fit. If this is true, then what battery pack is recommended. Please do not suggest Lipo's, I do not have the set up for those. Thanks. |
06-29-2007, 06:49 AM | #2 |
Quarry Creeper Join Date: May 2006 Location: Pirkkala, Finland
You could install a standard 6 cell pack on top of the servo (on the axle to get some more weight) with velcro? Or you can buy 2/3 size cells which should fit to the batteryarea. I haven't tried, but I think that'd work. |
06-29-2007, 08:33 AM | #3 |
RCC Addict Join Date: Jan 2006 Location: Irritable Isle
| www.unitedrc.com sells three packs that are designed to fit in the stock location. Like Tomik said, using a smaller battery on the servo will lower the CG for better crawling. |
06-29-2007, 01:53 PM | #4 |
Newbie Join Date: Jun 2007 Location: Over There
This is not stock, but its real easy to do. Just mount the tranny backwards and extend the front plate out so the battery will lay flat. I did this so I counld use all them 6 cell battserys I have laying around. No since in having different batterys for all your toys And a thanks to drc323 for the idea Last edited by MudHead; 06-29-2007 at 01:55 PM. |
