Do it yourself course inspiration So I was bumming round my second fav site in the whole wide web and came across these photo's from the W.E. Rock Canada stop and found them VERY interesting... EDIT: Here's the link to the fourm... http://www.pirate4x4.com/forum/showthread.php?t=605148 And the photo's I tried to load before... http://i8.photobucket.com/albums/a44...Erock20074.jpg http://i8.photobucket.com/albums/a44...8/100_0542.jpg http://i8.photobucket.com/albums/a44...8/100_0522.jpg http://i8.photobucket.com/albums/a44...8/100_0521.jpg http://i8.photobucket.com/albums/a44...8/100_0520.jpg http://i8.photobucket.com/albums/a44...8/100_0519.jpg http://i8.photobucket.com/albums/a44...8/100_0516.jpg http://i8.photobucket.com/albums/a44...8/100_0514.jpg http://i8.photobucket.com/albums/a44...8/100_0513.jpg http://i8.photobucket.com/albums/a44...8/100_0512.jpg |
Forbidden, I have a pirate login but others might not. |
oh... that's right... dang... :-( |
Even when I'm logged in to Pirate the links don't work. |
Links don't work. You need to save the pics to your computer, then host them elsewhere and post them here, or provide a link to the thread they are posted in. |
alright... leme fix this... sorry guys... |
Somthing different |
Yep... and PVC is cheap! |
I'm not shure pvc will work. I mean all you will do is slide around on it. You would need small diameter concrete pipe. |
Texture grey paint! :roll: |
It MIGHT work but you can usually find old drainage pipe laying around. |
I do the same sort of course already, Wood logs. |
best bet for grip would probably be that stuff you paint on stairs its cheap and easy to apply |
Latex paint and some sand will give you the same texture. |
Could alsouse some Cardboard tubes and fill them with Concrete,cut off the tubes after they dry......then you got concrete logs. |
Contact your local plumber he may have some concrete pipe from a job. |
Nothing a little spray adheasive and some sand couldn't fix then you could leave some slick spots on it to make it a little more challenging."thumbsup" |
