09-11-2007, 07:04 AM | #1 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
| sway bar
What's a good material to make a sway bar out of? It's for my 1:6 scaled rubicon jk. I want to stick a functional sway bar in the rear for stability.
09-11-2007, 07:19 AM | #2 |
Rock Stacker Join Date: Aug 2007 Location: Bensalem
wire coat hanger maybe?
09-11-2007, 07:39 AM | #3 |
| Could work but coat hanger wire doesn't have memory. Will it return to it's original shape?
09-11-2007, 08:39 AM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
I would use music wire. It's available in various sizes so you can "tune" it by making a thinner or thicker bar.
09-11-2007, 08:59 AM | #5 | |
http://www.smallparts.com/products/descriptions/smw.cfm This stuff? How thick you think i should go? It's a 1:6 scaled 15lb rig with clod axles and savage shocks (black springs). | |
09-11-2007, 09:19 AM | #6 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
maybe pushbike spokes? they have a memory sort of. not sure how long you'd need but it could work!
09-11-2007, 09:21 AM | #7 |
I'm not sure on the size you should try. Maybe get a few different sizes and see what works best. It's fairly cheap, and your LHS should have it in stock. Here is a tower link with a bunch of different sizes. Tower's prices look sky high, but it looks like they onlt sell it in large quantities. My LHS sells 36" lengths indivdiually, and they are only like a buck or 2 per length. http://www2.towerhobbies.com/cgi-bin...+WIrE&FVPROFIL=++ |
09-11-2007, 02:38 PM | #8 | |
09-12-2007, 09:39 AM | #9 |
$45 for a hpi baja sway bar kit including butt loads of mounting hardware. im sure there are other vehicles that use sway bars that would help your rig. http://www2.towerhobbies.com/cgi-bin...SWAY&search=Go |
09-12-2007, 09:57 AM | #10 | |
http://www2.towerhobbies.com/cgi-bin...?&I=LXLZY3&P=7 That's the only one that i found so far that would fit my clod axles (6"). There are alot of sway bars listed but most of them don't list the length. | |
