07-05-2004, 01:07 AM | #1 |
Quarry Creeper Join Date: Jan 2004 Location: Austalia
| Locked the rear diff...
hey..as u know i have an xfactor.. and i was going to lock the diffs with araldite epoxy...but i thought before i lock the diff up with the glue.. i might just flip a spider gear over.. well i flipped one over..and it still had a tiny movement before it was fully locked..so i flipped another spider gear over (one directly beside it) and it is know fully locked no movement..so will this work good or not?? dirk u prolly know..so yeh i have flipped 2 of the 4 gears over.. hope this works ryan |
07-05-2004, 12:24 PM | #2 | |
| Re: Locked the rear diff... Quote:
Good thinking Ryan | |
07-05-2004, 01:29 PM | #3 |
Pebble Pounder Join Date: Jun 2004 Location: Alberta, Canada
I tried to do that with my clod diff.............id didn't work...... :?
07-05-2004, 05:24 PM | #4 | ||
when i flipped one spider gear over..it was fully locked..but had a little play in between the gears..so i also flippe dthe gear directly next to it and it worked perfectly!! so today ill go out and try it!! toyo-will this last long?? i was told it wont? :? ryan | ||
07-05-2004, 06:28 PM | #5 | |
My rear diff, I blew on Saturday but it was actually welded via MIG welder. I have yet to open it up to see how much damage I did but it doesn't like to rotate now. Big rocks, lots of gear reduction, Kongs and a weaking rear diff don't mix: | |
07-06-2004, 07:01 AM | #6 |
well my buzz box..id going slower, lower..and longer now.. i hooked up 4 wheel steer today..put a 12t clutchbell on..will lengthen o 16 inches wheelbase..should go better!! btw..if the gears DO strip out..will i be able to glue the diff then?? will the glue method still work?? ryan |
07-06-2004, 12:21 PM | #7 | |
If you hear gears stripping... which you will if you haven't yet. It'll be the ring and pinion stripping each other out. You'll just have to shim the diff/ring gear closer to the pinion. But you may also strip the diff gears(the 4 little ones)... only time will tell. If you can, stock up on some spare ring gears | |
07-06-2004, 04:39 PM | #8 | ||
i have 2 spare new ring gears...and 1 spare pinion.. my only concern is the 4 spider gears..if they strip can u still glue them up? | ||
07-06-2004, 06:53 PM | #9 | |
07-07-2004, 09:02 AM | #10 | |
Rock Crawler Join Date: May 2004 Location: DFW, Texas
Oh and good thinking on the spider gears! I never thought of that one. If the gears do strip, I think u should just use jb weld or that epoxy stuff u mentioned. I jb welded my old black X- F diff that was stripped when I bought it, and it held up realy well. | |
