11-30-2007, 10:05 AM | #1 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Spring Rate Charts
I am using four 1/8 scale nitro buggy front shocks on my J2-TT comp rig with TLT Axles. I am using four 1/8 scale nitro rear shocks on my sons AX-10. I have encountered some difficulty tuning the suspension on both rigs and it has taken some time to find info on spring rates, spring length and how they compare between the different manufacturers. I like using the 1/8 scale nitro buggy shocks because they are strong. The shock shafts are all 3mm and the shock bodies are threaded aluminum. I run them upside down for a low C.O.G. They have been working well once you get the correct spring rate. Please feel free to correct or add to it. Hopefully it will be useful to someone. The first set is for Losi 8ight and 8ight T 1/8 scale: Front: Length 2.3" Gray - hardest 5.6 White Black Green Silver Red - softest 4.1 Rear: Length 3.1" Purple - hardest 4.3 Gray White Black Green Silver Red - softest 2.5 Spring rate chart for short on road style cars: http://www.rcingreece.com/index.asp?...rison&super=38 Spring rate chart in general: http://www.deccosoftware.com/forum/tech/SpringRates.htm LOSI SPRING RATES (onroad cars?) LOSA5108 1 Spring 20.0 Rate (Purple) LOSA5110 1 Spring 25.0 Rate (Black) LOSA5112 1 Spring 30.0 Rate (White) LOSA5114 1 Spring 35.0 Rate (Orange) LOSA5115 1 Spring 40.0 Rate (Yellow) LOSA5117 1.15 Spring 7.6 Rate (White) LOSA5118 1.15 Spring 8.6 Rate (Orange) LOSA5119 1.15 Spring 9.6 Rate (Yellow) LOSA5120 1.15 Spring 10.6 Rate (Pink) LOSA5121 1.15 Spring 11.6 Rate (Red) LOSA5123 1.15 Spring 12.6 Rate (Silver) LOSA5125 1.15 Spring 14.6 Rate (Blue) LOSA5126 1 Spring 17.5 Rate (Dark Green) TC3 and Nitro TC3 Springs Green 3941 12.000 lbs Softest Silver 3942 14.500 lbs Softer Blue 3943 17.000 lbs Soft Gold 3944 19.500 lbs Medium Soft Red 3945 22.000 lbs Medium Copper 3946 25.000 lbs Medium Firm Purple 3952 30.000 lbs Firm Yellow 3953 35.000 lbs Firmer White 3954 40.000 lbs Firmest XRAY SPRING CHART: YELLOW super soft 14 lbs. WHITE soft 17.5 lbs. BLUE soft-medium 22.5 lbs. VIOLET medium 28 lbs. PURPLE medium-hard 33 lbs. RED hard 38 lbs. |
11-30-2007, 04:14 PM | #2 |
MODERATOR Join Date: Jul 2004 Location: Ohio
We like pictures. Losi springs.
11-30-2007, 04:33 PM | #3 |
Pictures are all that some people look at. This way we trick them into learning. Springs with part numbers below. Last edited by Grizzly4x4; 11-03-2008 at 11:58 AM. |
11-30-2007, 07:21 PM | #4 |
Your awesome EeePee . Thanks for the pictures.
06-26-2008, 02:42 PM | #5 |
Quarry Creeper Join Date: Jan 2005
| Spring Rate Charts
Thanks for referring me here Nova's Ark. Does anyone know what the spring rate of the stock red Traxxas XXL Big Bore shocks is so that can used as a comparison with the Losi spring rates? I have the red Traxxas springs on the aluminum Big Bores and they are way too stiff......Thanks as always for any input!
08-07-2009, 08:00 AM | #6 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I just wanted to add one. They now have a Gold 2.75" spring with a 1.4 rating
08-07-2009, 10:15 AM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| I'm running gold front, gray rear springs on my big bores. Losi Springs Part # length rate color 5144 2.75 1.4 gold 5146 2.75 1.6 gray 5147 2.75 1.8 white 5148 2.75 2.0 yellow 5150 2.5 2.3 pink 5152 2.5 2.6 red 5154 2.5 2.9 orange 5156 2.5 3.4 silver 5158 2.5 3.7 green 5160 |
07-23-2010, 05:00 PM | #8 |
Does anyone know if there is anything softer than the Losi 1.4" ?
07-23-2010, 07:22 PM | #9 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
there is but I've only seen the Losi guys have them... i believe they're black or really dark grey. And the wire itself is super thin...
07-23-2010, 07:33 PM | #10 |
Pebble Pounder Join Date: Jun 2008 Location: PISCATAWAY
This is a great post maybe it should be a sticky |
01-17-2011, 06:38 AM | #11 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
Anyone have the rates of the mini t springs?
01-17-2011, 07:23 AM | #12 |
I've looked for those myself but came up emtyhanded....however, I believe the red mini-t spring is close to the Gold and the pinks are quite a bit softer than that.
01-17-2011, 10:09 AM | #13 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
Also has anyone checked the new axial springs vs. the losi golds? I have some of the new 1.04's and they seem stiffer than the losi golds to me....what say you?
01-17-2011, 11:06 AM | #14 | |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
01-17-2011, 11:31 AM | #15 |
| Both springs were brand new? Or were the golds well used? As springs get over compressed and then stretched out again, the spring can become damaged and feel softer...
01-17-2011, 11:56 AM | #16 | |
That is a great idea...I have one of those in my racing stuff | |
01-17-2011, 11:57 AM | #17 |
01-18-2011, 06:28 PM | #18 |
Ok so here is the test I did tonight taken by my Droid Last edited by clarkrw3; 01-18-2011 at 06:35 PM. |
02-06-2011, 07:02 PM | #19 |
02-06-2011, 07:24 PM | #20 |
RCC Addict Join Date: Sep 2006 Location: Depew
