longer stub shafts? I have a hi Lift I am running 2.2s on and the Stock stub axles in the hub are barely long enough to grab the Nylon for the wheel nut. I am hoping to run the thicker grey Traxxas 12mm hexes but then the shafts will be way too short and I will loose wheels constantly. I know the hot trick on the TLT was to run Blackfoot stubs, but would this work on the Hi lift? other then something like this I need a narrow set of wideners I am looking for only like a 1/8th inch so I do not need anything as big as the Junfac or similar kits. Any help would be appreciated |
Rears for the Tamiya TG10. |
i run these long axles without having to do any mods to it. direct bolt in. you can run the wider traxxas hexs or your can even run 1/2 cvd spacer with no problem. http://rcpcrawlers.com/product.php?p...&cat=17&page=2 |
Beat ya! "thumbsup" |
thanks guys you rock. Thanks for the assist. It seems like it is always tricky to do a smaller mod. On alot of this stuff it is still all or nothing, and I just don't want to widen my truck so it is like a foot wide. |
