Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: Most Durable Crawler
Old 05-20-2005, 12:59 AM   #1
Default Most Durable Crawler
I know, everybody has their favorite and "clods rule" but what I want to know is which crawler is the tuffest. What I want to hear is what rig you have and what are it's weak points.
I don't need to know about the little trucks. I have a TLT and I know how to break it. I am gearing up for a big truck build and I don't like fixing things all the time. So how tuff is the clod?? Who has the tuffest axles?? What is the toughest tranny??.
So guys what are you breaking and also what size tire and gearing are ya running on your rig when you broke it.
DUDE is offline   Reply With Quote
Old 05-20-2005, 02:36 AM   #2
2006 2.2 National Champ
BENDER's Avatar
Talking Txt
I've owned a TXT and an E-maxx since the day they hit hobby stores, I've broken more on the E-maxx. The only thing I've broken on the TXT is a few inner axle shafts, that was running an EVX with dual batteries, stock tires, locked diffs and 10t pinions, and I managed to break an axle housing. It was the cap that the upper links mount to on the axle that broke, and it was a big tumble. The TXT tranny is bulletproof, the kit include 2 sets of tranny gears and I haven't had to use the spare set yet. I do strongly suggest running full bearings, worn bushings will kill gears.
Clod axle tubes are weak. I've seen them break on rollovers that weren't that severe.
I know Twin Force axles are tough too, but I've never owned one.
BENDER is offline   Reply With Quote
Old 05-20-2005, 09:01 AM   #3
RSI
i got twin axles and ive had txt axles and i have clod axles.... ive never broken any txt axle parts... i had fried a set of txt tranny gears the twin axles i broke the little ear where i mount my lower links because it fell like 8 feet.... and the clods i have only broken the carriers.... where they connect to the steering links but that was because it fell off the same wall lol
ryan
RSI is offline   Reply With Quote
Old 05-20-2005, 09:25 AM   #4
Ace
Clods do break, but if you carry an axle tube and a knuckle your covered for 94.9% of the possible problems.
When I drove my shafty I felt I had to carry one of EVERYTHING.
Ace is offline   Reply With Quote
Old 05-20-2005, 09:31 AM   #5
Colt Python/SR9c
TwistedCreations's Avatar
I run an emaxx. I use no crappy plastic emaxx crap. i only use the diffs,steering knuckles,maxx trans locked into 1st...that is all i use basically, the rest is cvd's,revo shafts,etc.etc. the only breakage i have had is a servo mount( my fault) and rod ends. i used the cheap traxxas rod end crap and since upgrading to Dubros monster ends, i have had no breakage at all.run lst's w/ gd600, so it has all the torque in the world to break shit, but i don't
it's not the question of which truck is more durable, it is how you build it. if you build a truck cheaply, it will be a POS and break. but if you put some money into it,take your time and design it right, it should last. but in crawling, shit breaks! there is noway around it
TwistedCreations is offline   Reply With Quote
Old 05-20-2005, 10:07 AM   #6
I have a txt with txt axles and tranny and a gd600 with a 15 tooth on a m.m and i'm running cut bft on narrow txt wheels with revo drive shafts and i have never broke anything. I also have a txt with xfactor axles also with a gd600 and a m.m. with a 15 tooth with tmaxx drive shafts on a set of kongs and also never broke anything.Also i have a v2 with lathe motors with 9 tooths front and back with also cut bft on maximizer bead locks and i have broke a front driver side axle
1beatjeep is online now   Reply With Quote
Old 05-20-2005, 02:22 PM   #7
TEAM MODERATOR
Reflection's Avatar
I'll have to agree with Jeremy,if you build it cheap it'll be cheap and probly break. Build it,nomatter what rig you start with,with good quality parts and design it right,it should last a good while and provide pleanty of fun.
I'm running a Twin Force rig. I do believe that Twin axles will handle anything you can throw at them. All I've done is upgraded the factory aluminum ring and pinion to the steel helical cut gears. I'm locked solid all the way around and running Kongs,I've not broke the first thing in my axles.
The Twin tranny is IMHO also very strong. The only thing I've broke in the tranny is the plastic 50 tooth spur gear. In all honesty it was probly my fault because the gear mesh was probly to sloppy. The drawback to the Twin tranny is the only spur gear available to bolt up factory without any mods is the stock 50 tooth. Theres a guy thats modded his to take the Maxx style spurs and can use up to a 70 or 72 tooth spur. I've got an idea and am in the middle of doing it now but I'll be able to run any maxx style spur. The way I'm modding mine should be easier to do and will use all factory parts,so no need for custom made or modded parts.
Between the chain drive in the tranny, the 8mm outputs and inputs and everything holding up to running locked with Kongs,the only thing I've broke is a couple factory spurs. IMHO the Twin Force is a very durable rig.
Reflection is offline   Reply With Quote
Old 05-20-2005, 02:26 PM   #8
Originally Posted by BENDER
.....Clod axle tubes are weak. I've seen them break on rollovers that weren't that severe.....
Guess you haven't downloaded this: http://www.gerrish.net/waterfall.wmv
I basically did a durability test at 14.4 volts and a 12 foot waterfall, OVER and OVER and OVER again...... and nothing broke! I basically drive it like I stole it for over two solid minutes of attacking that waterfall hoping I could somehow jump it up the lip at the top, but it never happened!
But I have also seen them (clod axles) break on really mild stuff...... Thats why I carry spares.....
4RnrRick is offline   Reply With Quote
Old 05-20-2005, 02:48 PM   #9
06 Super National Champ
JasonInAugusta's Avatar
Most durable?
Anything that's not driven by Dirk.
I have yet to snap stub axles or anything on the TXT, but I have more of a finesse driving style.
On the Clods I snap axle tubes fairly often...need some aluminum tubes.
JasonInAugusta is offline   Reply With Quote
Old 05-20-2005, 05:42 PM   #10
BENDER's Avatar
You got lucky, Clod axles are the weakest available. One 2 second clip of you beating on a Clod doesn't change it.
Old 05-20-2005, 09:44 PM   #11
My x factor is a tuff little SOB. I`ve nose dived it, ran the axel into a pole, and busted many rear driveshafts (When I get the revo one in you can try all you want you big block SOB) I have used the stock tires with unlocked diffs for now, and all I have broken is one front link (the nose dive) and a steering link (the pole) the rear shaft sucks anyways.
RampageFSJ is offline   Reply With Quote
Old 05-21-2005, 02:29 PM   #12
Location: orange county n.y. , building the hydro crawler
I used to blow gears in the pede tranny when i was in a bind, because it would twist the case under extreame torque loads. Now i run a custom machined t case with 2 inline gd600s. Links are 1/4 hardened steel. As for axles i run maxx diffs, with custom steel 3/4 id axle tubes, 1/4 thick steel link mounts, 1/8 thick diff housing, steel c hubs, i can drive it off a cliff.
weakest points are the traxxas rod ends, and a maxx shafts (whick will become revo shafts soon).
Not like i need to worry about rollovers with my cg with the new t case i can mount the motor on the back axle, battery on the front.
sambmx is offline   Reply With Quote
Old 05-22-2005, 01:55 PM   #13
Clods surely aren't the strongest.. They weren't made to have 7" tires, 9tooths and lathe motors with tons of power. Tubes are weak, but if your braces are tight you'll eliminate most your problems. The knuckles are fairly beefy. I just have a problem with inners now, which SUCK to replace.
From what I've seen on here, I'd give the TF/XF the overall nod.
SR5Dave is offline   Reply With Quote
Old 05-22-2005, 08:32 PM   #14
CSR
TXT's are tough. My truck has been crashed and abused a lot since I built it a year ago. Full throttle, Mag Mayhem, 7-cell rock racer! If it can't be crawled, I'll jump it! The only TXT parts that I've broken have been stub shafts.... one broke from overtightening, the other bent in a hard crash. I went thru several Maxx slider shafts before stepping up to Revo shafts, now it's good.;)
CSR is offline   Reply With Quote
Old 05-23-2005, 12:49 AM   #15
Aren't TXT inners similar to clod inners? How have those held up for you?
Old 05-23-2005, 01:00 AM   #16
It's a setup!
jason's Avatar
I have had a maxx crawler, a txt-1, and several clods. Notice I said several clods, because to me a clod was the only one worth redoing.
With my maxx running a gd600, 55 turn, 1 battery and super rooster, I could snap the stock plastic axle shafts driving on flat concrete. I bought CVD's and snapped one within 5 minutes, I parked it and never drove it again.
With my TXT, I only had maybe 10 hours of running it with stock tires and completely stripped every gear in the rear diff. Parked it never drove it again.
With the several clod based rigs I've had sure I snaped a few stub shafts, broke several tubes, and broke a couple of knuckles. Anyone that has seen me drive knows I beat the hell out of my rigs, and like I said out of those 3 I'd take a clod any day.
jason is offline   Reply With Quote
Old 05-23-2005, 06:53 AM   #17
there is a very simple mod to make the axle tube very simple to replace.i've seen this used before and use it my selfe and works great.
take the gear box a part,remove the 4 screw & nuts that hold the tubes on off,put gear case back together,place tube in place and place 4- 6/32 screws in the tube holes and tighten them in place.don't use to long of a screw.and install every thing else.now when you need to replace a tube just remove the hub and those 4-6/32 screws and the tube is out in your hand. don't even have to remove the axle from the truck and it's fast to do
SPEED_RACER is offline   Reply With Quote
Old 05-23-2005, 09:27 AM   #18
Colt Python/SR9c
Originally Posted by jason
I bought CVD's and snapped one within 5 minutes, I parked it and never drove it again..
what CVD's did you buy?
Doug has snapped the cheaper ones before, but i have yet to snap a MIP :?
Old 05-23-2005, 08:42 PM   #19
CSR
Same part #. (Knock on wood) I have yet to break an inner. I've watched KillerTXT and our buddy Tripp break countless inners with their TXT's. Only thing I can come up with is maybe their rigs are heavier and/or geared lower than mine. Maybe I'm just wheelin' on borrowed time..... all four axles may snap at once the next time I run the truck!
