05-23-2008, 08:51 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: northern utah
| trailer hitches
hey guys i built a trailer to tow my rigs around and i was just looking for some ideas for the receiver part of the hitch, what did you use and how did you attach it to the truck? also what is everyone using for the tongue on the trailer, just a ball cup? any pics or info would be much appreciated! thanks
05-25-2008, 12:19 AM | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I used some 3/8" box tubing. I welded it into a bumper and bolted it to the frame. Then I used some 1/4" square aluminum stock for the drop hitch and bolted a large ball joint to it. The tongue of the trailer is some 3/8" U channel and bolted the same 1/4" stock into it drilled a hole into the end for the coupler. If you look close you can see the hitch set up |
05-25-2008, 01:15 AM | #3 |
Newbie Join Date: Jun 2006 Location: San Jose
Hi. I just used a 1/4" steel square tube & a 1/4" solid square bar from our local home depot. The drop was an aluminum angle stock which I cut and slightly bent out. I can't weld so I drilled and tapped a 6/32 screw to hold the angle to the steel bar. The whole thing was bolted to the bottom of the bumper. The ball is standard link ball from TLT. when I don't use it, I use a 1/4" plug also found at home depot. Hope it helps. tks |
05-25-2008, 01:55 AM | #4 | |
Rock Crawler Join Date: Apr 2007 Location: Nor*Cal
05-25-2008, 01:11 PM | #5 |
wow those are some nice hitches guys! thanks for the pics!
06-10-2008, 07:09 AM | #6 |
Pebble Pounder Join Date: Oct 2007 Location: gig harbor
here the hitch i built from brass sq. stock and some solder. made from three different sizes they all fit in nicly in each other. |
03-05-2009, 11:47 PM | #7 |
Newbie Join Date: Jan 2009 Location: Taylorsville
| nice
This is probably the best looking hitch i've seen so far. Keep up the good work
03-06-2009, 07:07 AM | #8 |
Quarry Creeper Join Date: Nov 2007 Location: NH
I took the easy way out. receiver hitches are cool but I went with the home brew step and tow bumper route |
03-06-2009, 09:38 AM | #9 |
03-07-2009, 01:11 PM | #10 |
Rock Stacker Join Date: Apr 2008 Location: oshkosh
| trailer
so you say you are building a trailer. I am thinking of doing the same but so far all the aluminum channel is sitting in the corner of my shop doing nothing. if you have any hints on how to start building let me know would you please.
03-07-2009, 08:23 PM | #11 | |
I used styrene to build mine rather than aluminum or steel, but it won't be carrying any real loads either and I just wanted it to look really scale. There's a link to my trailer build in my sig below...maybe it can give ya a kick in the pants and get you motivated to start on yours. | |
03-09-2009, 06:47 PM | #12 |
Rock Stacker Join Date: Nov 2008 Location: howell
some food for thought...... trailer in progress |
03-10-2009, 03:59 PM | #13 |
Quarry Creeper Join Date: Mar 2004 Location: n.e. ohio
Made these from 3/16 and 1/4 inch brake line and 1/8 and 3/16 keystock from harbor freight. I use a vise to push the keystock into a section of tubing into the flared end. Then use a hammer to flatten out the flare on the 4 sides. A dremel,grinder, ect. to grind it flat on the end and presto! You have a hitch with the strengthening ring around the outside edge. |
03-10-2009, 04:12 PM | #14 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
i used a tamiya ball stud and a rod end....i also just made a bracket that i attached to the back of my chassis that came over to the body and out right below the back fender....(no pics of it though, sorry) u can kinda see the rod end here...also if you cant find a ball stud, a grease zert will work as well... |
03-11-2009, 06:24 AM | #15 |
Quarry Creeper Join Date: Oct 2008 Location: Allentown PA
Ok how do I make hitch to fit my F350 does any body have any ideas for that type of truck? Thanks Greg |
03-11-2009, 06:32 AM | #16 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
this is probably the coolest thread ive seen to-date! 2-thumbs up guys for originality and builds. |
08-22-2014, 09:09 PM | #17 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: trailer hitches
I just finished my hitch, it made out hardware and key rings I got every at my local Ace hardware, I love that place.
