07-26-2008, 08:27 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
| brake tubing to aluminum?
Want to start building a scale rig and like the shape of the X-trail. I want to build off it with 3/16 brake tubing. Hows is the best way to attach it? Does anyone make a metal look-alike X-trail that I can weld the tubing straight to?
07-27-2008, 02:42 PM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: barre
you could make mounting tabs at the ends of the cage,rock sliders or whatever you want to bolt the tubing to the frame thats what i see alot of on here
07-27-2008, 04:01 PM | #3 |
thats the only thing I could tink of. Would rather use a metal chassis I could weld straight to I think
07-27-2008, 05:49 PM | #4 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
Maybe insert 3mm allthread into the 3/16 tube, braze, and attach it to the frame.
07-28-2008, 08:43 PM | #5 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
You can always braze the brake line to the x-trail instead of welding it. Accomplishes the same thing, you'll just have to use a torch instead of a MIG/TIG if that's what you're using for your tube work.
07-28-2008, 09:22 PM | #6 |
wont be able to braze steel to aluminum aluminum has a way lower melting piont
07-28-2008, 10:08 PM | #7 | |
http://www.lucas-milhaupt.com/htmdoc...ing_about.html Last edited by Trike Kid; 07-28-2008 at 10:16 PM. | |
07-29-2008, 03:59 PM | #8 | |
http://www.muggyweld.com/melting.html Last edited by frsttimer; 07-29-2008 at 04:01 PM. | |
