01-27-2009, 07:26 AM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: Rochester Hills, MI
| JK driveshaft ?
I am starting a jk build and I would like to know what drive shaft's to use. It has 13in W/B, custom delrin chassis, Ax10 axle's and trans with 4link. I am running 2.2 flat iron's. If possible I would like to see pick's please and also pick's of flat fenders. Thank you
01-27-2009, 08:35 AM | #2 |
I am running Pede shafts
01-27-2009, 08:48 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Not to be rude, but you already answered your question. Use Axial driveshafts! You have everything else axial. |
01-27-2009, 08:56 AM | #4 |
01-27-2009, 03:02 PM | #5 |
Quarry Creeper Join Date: Nov 2005 Location: Louisville, KY
Im using pede shafts with metal end joints. On the front where the driveshaft is longer I took a female end and a male end with the joint part cut off and epoxied it inside. You could probably do the same with the axials. Then used another female end on the other side not epoxied so that I still get the slip action. Most people run a 13.75" wheelbase on the j/ks so you may want to re-check what you got.
01-27-2009, 04:09 PM | #6 |
Pebble Pounder Join Date: Nov 2007 Location: Grand Rapids
I must of gotting long drive shaft with my kit then because i am using the stock axiel driveshafts that came with the ax-10 kit with my JK.
01-27-2009, 04:34 PM | #7 |
Rock Crawler Join Date: Feb 2007 Location: Simi Vly
No doubt, if you already have the Axial kit , use them, not long enough. extend them. That is what has been done with the pede shafts.
01-27-2009, 05:43 PM | #8 |
Ill just have to measure it once its built. Guess that would be the easyist way to find out. Thanks guys
01-28-2009, 05:14 AM | #9 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Mine used to pop out under full articulation, so I went and did what maxxa did and glued one together and cut it apart to make it longer.
01-28-2009, 05:56 AM | #10 |
Oh I just had a thought. Maybe I could use the output extension that came with my r2d since I didn't use it on my comp truck. Ill just have to get another one for the front.
