12-10-2010, 09:08 PM | #1 |
Rock Crawler Join Date: Sep 2004 Location: eureka
| led wiring ?
so i started to wire up my yota scaler tonight and ran into a problem. ive got the rc4wd light box that can either run off the receiver (with a bec im guessing) or a 4aa battery pack. problem is that sense the lights are mounted to the body I would be either stuck mounting the light box to the body along with the battery to run it which would make it too top heavy , or just mount the controller box to the body and have to unplug it from the receiver any time i take the body off (which doesn't sound ideal either..) just wondering how other people are running their wires to the body so that its not a pain to deal with? |
12-10-2010, 09:36 PM | #2 |
Newbie Join Date: Dec 2010 Location: North East
One think that i have used for previous light installs to make them easy to disconect is a Deans 2B plug. Might work for your application, or it might be too big, when using this you will need to be decent at soldering. this might be the correct video that shows the connectors, if you look through my photobucket account you will see 4 videos on how i did my light set up. There is also one on You tube. here are the links http://s270.photobucket.com/albums/j...urrent=527.mp4 http://www.youtube.com/user/spruceha.../0/MFfWUDQlFH4 I hope this helps. |
12-10-2010, 09:41 PM | #3 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
i've had an idea in the past to run washers on top of body posts and washers over the holes on the body (power from the pack or BEC to the washers on the posts, and wired to your lights from the washers on the body) so when the body is mounted the washers contact and finnish the circut. just an idea. brass or copper washers might be a good idea so you can easily solder to them. good luck. |
12-10-2010, 09:46 PM | #4 |
^thats an awesome idea, thanks ill probably give that a try
12-10-2010, 09:47 PM | #5 |
That is a really good idea, i have used that on my 1:1s before for differnt reasons.
12-10-2010, 10:07 PM | #6 |
i'm glad some of my idea's are "awesome" if the lights cut in and out cause the body jostling around, small springs might be an idea.
12-11-2010, 10:39 PM | #7 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
X2 on the deans. I use 2R (LHS does not carry the 2B) plugs with +/-24AWG high strand count wire so stays flexible. I always leave enough slack to remove the body and lay it next to the rig so I have both hands avail to unplug them. I bring straight 6v up under the bodies, then break it out to the voltages that each LED type needs. I do not use body posts, but the washer idea is pretty cool. Post up some results after you try it! |
12-11-2010, 11:34 PM | #8 |
Rock Crawler Join Date: Dec 2009 Location: Ontario Canada
I have the LEDs mounted in my body and the LED controller is mounted on the body as well...I just have to disconnect/reconnect a servo plug to the LED controller to remove the body...but I never really "remove" my body as it's bolted directly to the chassis on a hinge. so I just lift the front part of the body Attached to frame with velcro) to get access to the battery. (Mine is setup so you plug in the battery the truck turns on automatically)
12-12-2010, 02:03 AM | #9 |
Quarry Creeper Join Date: Jul 2010 Location: netherlands
I have 4 lights in the body, the controlbox is mounted on the chassis. everytime I put my lid on or of I have to unplug 4 led's from the controlbox |
12-12-2010, 01:48 PM | #10 |
I have lights on my frame and body, I used a couple old servo leads to make a plug between the bumper lights and headlights. I figure mini Deans would work fine also.
12-12-2010, 09:19 PM | #11 |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
I used the coil springs from an old reciever bat holder. Mounted them near the body posts. The body has a couple brass washers for pickup contacts. Drop the body on and the lights get power. No extra plugs, switches, wires or flickering to worry about. |
12-12-2010, 09:54 PM | #12 |
Rock Crawler Join Date: Nov 2010 Location: Denver
Thats and awesome idea ThunderVP
01-06-2011, 11:54 PM | #13 |
Pebble Pounder Join Date: Dec 2010 Location: old bridge
| shorts?
does doing the ol' spring and washer trick short out when going through water or because its D.C. it ok? i use to use my dewalt drill under water when i was an electrician and was had to do underwater lights... just curious... if its all good then it how i am going to do my lights. best idea i have seen so far... awesome awesome idea... |
01-07-2011, 12:54 AM | #14 | |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
01-09-2011, 08:09 PM | #15 |
| niceeee...
thats what i thought... sweeeet... thank you... |
