10-10-2011, 06:14 PM | #1 |
Newbie Join Date: Sep 2010 Location: usa
| opening doors
has any one made doors on their lexan body that open and close. I want to do it to my cherokee body but its brand new and i dont want to ruin it. if so could you please post pics? Thanks
10-11-2011, 08:59 AM | #2 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
it's really tough to go doorless or have opening doors with a lexan body since the lexan isn't very rigid. Cut a door opening without adding a lot of reinforcing and the whole shell will twist and crack when you flip it. Most of the guys who I have seen do it have custom full interiors with roll cages that the shell is attached to for support. Most recently I saw a guy do a doorless XJ using a chopped up Wraith interior and cage. You would usually expect the interior and cage to be chassis mounted, but in this case they are perminently attached to the body and support it. Last edited by Mud Puppy; 10-11-2011 at 09:04 AM. |
10-11-2011, 09:42 AM | #3 |
RCC Addict Join Date: Oct 2007 Location: gervais
Also search for Szczerba on here, he also had a build involving the Cherokee and had the doors cut out and used styrene tubes to make a rolecage inside the body
10-11-2011, 07:31 PM | #4 |
im building an exo cage so the body should be fine and ive seen Szczerba's Cherokee. i will just try it if it doesn't work i will probably just make it door less. thanks anyway.
