Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: Boyer 1/10 Scale Truggy Chassis questions
Old 12-28-2011, 03:38 PM   #1
Default Boyer 1/10 Scale Truggy Chassis questions
Hey folks had a search about and was unable to find an answer so figured id try a thread and hoping someone could shed some light on it, been thinking about buying the above but have heard the welding on the shock mounting plates leaves a lot to be desired and is somewhat crap and flexy but i don't know if thats just fact or just gossip not a lot of info about them over here in england, also would the running gear from a scx10 mount up to it ok ( think i read somewhere it would if it was raised up a little)i cant see the axles and links being a issue was not sure if there is a enough room to get the Transmission in there, or would i be better off buying the rc4wd tranny?
Thanks
Karl
KarlP is offline   Reply With Quote
Old 12-29-2011, 07:42 PM   #2
Default Re: Boyer 1/10 Scale Truggy Chassis questions
i have a timber wolf that is the welded one and switched the running gear to axil,and i have weld to it aswell,i turned it into truggy and i havent had no problems with,i was having problems with the ring and pinionwith the rex 60 axles,idk if this helps
arrowbee is offline   Reply With Quote
